Hi,
I've upgrade directly to Catalina from my previous Mojave installation almost everything seems to be working expect for when I try to Shutdown or Restart the Hackintosh as it will switch off or restart but won't reboot, unless I first run recovery mode and the restart again after running the terminal command "sudo halt" . I can also shutdown in Catalina with command sudo halt and when it is turned on it starts without issue
Specification
·          Motherboard : Asus Maximus IV Extreme-Z
·          Processor : Intel Core i7-2600K 3.40GHz (Sandybridge)
·          RAM : 16GB DDR3
·          IGPU : Intel HD Graphics 3000
·          eGPU : Sapphire RX 580 Pulse 8GB
·          Storage :  Samsung SSD
·          Ethernet : Sapphire RX 580 Pulse 8GB
·          Wifi : Broadcom BCM94360 Dual Band 1300Mbps 802.11AC PCI-E WiFi Bluetooth 4.0 Adapter
·          Audio Codec : Realtek ALC889
·          Monitor Resolution : Full HD 1920 x 1080
Due to upload size restriction I've uploaded the RunMe, with the Clover folder. But have the following Kexts installed in the other folder
·          AirportBrcmFixup.kext
·          AppleALC.kext
·          AtherosE2200Ethernet.kext
·          BrcmFirmwareData.kext
·          BrcmPatchRAM3.kext
·          CPUFriend.kext
·          EAPDFix.kext
·          GenericUSBXHCI.kext
·          HibernationFixup.kext
·          IntelMausi.kext
·          Lilu.kext
·          NullCPUPowerManagement.kext
·          realtekALC.kext
·          RealtekR1000SL.kext
·          SMCProcessor.kext
·          SMCSuperIO.kext
·          USBInjectAll.kext
·          VirtualSMC.kext
·          WhateverGreen.kext
Thanks for any help that can be provided
Send me Mac-Pro.zip config.plist.zip
ur problem is GenericUSBXHCI.kext
remove and test
