I want to install catalina 10.5.6 on my laptop, but after select the installer and booting, the process got stuck on some problem like this.
https://ibb.co/740S851
Does anyone have this problem?
MSI GF63 Thin 9SC-203NL
Specification :
- Processor : Intel Core i7-9750H
- RAM : 16GB DDR4 PC21300 / 2667Mhz
- IGPU : Intel UHD 630
- eGPU : Nvidia GTX1650 Max-Q
- Storage :  NVMe Kingston SSD + 1x WD blue 1TB
- Ethernet : Realtek PCIe GbE Family Controller
- Wifi : Intel AC 9560 and Bluetooth
- USB : Intel Chipset
- Audio Codec : Realtek ALC269
- Touchpad : Synaptic PS2 Interface
- Display Size : 15.5 Inch
- Monitor Resolution : Full HD 1920 x 1080
u try a date fix?
date 111110232019
after language screen u dont have access in terminal?
Yes, the screen show the error like the one i post above.
burning again or create new installer
It's just same result even i try made new installer of many macos version. Does Virtual Box could made some conflict with hackintosh install?
Specification :
- Wifi : Intel AC 60 and Bluetooth
please if u build efi u can upload because i need EFI Folder
This efi has problem that hasn't solved yet. Does your MSI has same specc?
