Hi!
I have a problem about booting macos Mojave and Catalina.
Booting to half and shutdown,no restart.I don't know if that's what the motherboard doesn't have AHCI SATA or something else...
I will attach pictures with booting before shutdown.
My previous motherboard GA H61M-DS2 work perfectly both macos.
My now spec PC:
Asus H110M-R
i3 6100 - 3,70GHz
mem 4gb 2400mhz
intel graphics uhd530
160gb hhd wd
Please help or advice, thanks in advance.
IMG-0562.zip
Yes
if need configure quirks
5 minutes ago, IgorilaX said:
I have graphics MSI GeForce gt 120 1GB.To try?
gt 210? only high sierra. change it
1 hour ago, IgorilaX said:
Ok but this graphics running on Mojave?
with drivers from high sierra, not native
I know.I will try to continue with the integrated graphics.
I just don't know why it's hard to boot a system with my motherboard?
No surrender...
hd530 is much better but sleep dont work
ye ;)
16 minutes ago, IgorilaX said:
How do I solve that?
need remove -igfxvesa
