I have installed opencore 0.6.2 on my asus N552VW, i would like to take off my DSDT, but skylake controller patch is required for i2c1 operation, is it possible to make a hotpatch?
dsdts.zip
Edited by gannicus00
hot patch is a non-sense incomplete solution
we don't use it here
if u need a full solution with hotpatch check daliansky work
On the opencore guides, it is recommended not to have a custom dsdt, so I was looking for a solution for the SKL controller ... thanks for the reply
just ignore it
opencore and clover support override
