Sleep/Wake issue with Catalina 10.15.7
Hi Guys,
I am having a fully working Catalaina HACK except for the sleep/wake issue.
After a week's time I figured out today that the HACK is not going in to sleep because of a sound card that I have in place where after removing it, I am able to get in to sleep mode properly. But the real problem is I need this sound card for my Windows 10 which is running as the other OS in the machine. So I installed the Asus Xonar AE back in to the slot and I now research on how to disable the PCI Sound Card alone - as things would work as it should.
I have gone through some discrete GPU disabling procedure but it is not suiting my need and hence I would like to know a way to disable this sound card using DSDT/SSDT, if possible.
Any help would be highly appreciable!
Thanks in advance!
File from RunMe App: https://we.tl/t-UmmAJpYNNF
My Specs:
Processor: Intel i7-4790K
Motherboard: GA-Z87X-UD5 TH
GPU: Sapphire RX 5700XT Nitro+
RAM: 16 GM Corsair Vengeance 1600 MHz
Edited by arunhk3
use it, reboot and save one ioreg. remove all ssdts
40 minutes ago, arunhk3 said:
Used the attached DSDT.aml & rebooted.
THE CONFIG LOOKS GOOD NOW. I THINK THIS PROBLEM IS USB 3 CARD
On 10/10/2020 at 9:09 PM, MaLd0n said:
check if work
Hi MaLd0n,
I could not see the device now in IOReg and also I switched over to Big Sur Beta 9, where the sleep is working fine now. But I have to wake the device by using the power button where the mouse/keyboard (or) any USB device doesn't work.
But I could manage with it!
Word of appreciation: I have been to many forums seeking help but I have not received a reply like this from any other sites. You are so wonderful and I pray that God bless you for your actions and heart! I am unable to PayPal, so finding another way to send a small donation to you!
Thanks a ton!
Edited by arunhk3
check if work
have via bitcoin, i think mercado livre accept all things too
2 hours ago, MaLd0n said:
check if work
I made a donation through PayPal itself. Payment via the link didn't work but after logging on to PayPal, I could use your email to make the payment!
Sent a message to IGERSLIKE (Moderator) in Discord (TriSool is my Discord Name)
Thanks a ton again!
check if work
I tried this DSDT and it enters in to sleep where all the USB devices go to sleep for sometime (lights in the tower goes off), but it kinda wakes up immediately where all the lights in the tower goes ON again as well as the keyboard/mouse lits up except for the display which stays off.
Once when I move the mouse the display comes ON.
Typically all the lights would stay off like a real mac, once when we touch the keyboard/mouse the lights in the tower as well as the display comes springing back up. So I wonder what the problem could be now!
Edited by arunhk3
Ye
Appear in some cases
Use previous dsdt
