Hello, I've been trying to edit my own DSDT since there are no pre-edited ones out there. But I still can't get it to compile.
I've applied these three patches: _T_x rename, WAK, and Possible operator timeout is ignored, which fixed a lot of errors, but I could only get so far on my own.
Now I'm stuck with these five errors:
2100 Warning ResourceTag larger than Field (Tag: 64 bits, Field: 32 bits)
2314 Error Invalid object type for reserved name (found ZERO, requires Buffer)
9892 Warning Not all control paths return a value (_HID)
9892 Warning Reserved method must return a value (Integer/String required for _HID)
10439 Error _HID suffix must be all hex digits (GH)
Google gives me irrelevant answers, so I'd appreciate any help with this.
I attached my unedited DSDT if that would help too.
DSDT.dsl.zip
Edit:
After about 4 more hours of work I've managed to get down to 1 error:
"Reserved method must return a value (Integer/String required for _HID)"
"Not all control paths return a value (_HID)"
Actually two errors, but both come from the same place (line 9894):
            If (TCMF) {}
           Else
               Return (0x0201D824)
I fixed it by adding making the if statement return the same thing for both conditions:
            If (TCMF)
               Return (0x0201D824)
           Else
               Return (0x0201D824)
But I'm not sure if this is the proper way to fix the problem.
The ACPI specification says it returns a hardware ID for plug and play devices. But I still don't know what exactly it should return?
Edit 2:
I made my own fix for the error above though I'm not sure if it's the correct one, but it works.
Files attached here + DSDT Editor patch file for anyone else with this motherboard.
Patched GA-H77M-D3H.zip
Cheers.
The "If (TCMF) {}" is there for a reason. It simply says that if TCMF is true then do nothing. Returning something at this point would be wrong so I suggest you should find a better solution to this problem.
I'm also having the same problems as you so you're not alone. This happened after I flashed the BIOS to the latest REV. And I'm using "Asus P8P67 WS Revolution B3" btw.
The most annoying issue here is obviously the one error: "_HID suffix must be all hex digits (GH)". So if you've found a solution for that, please report back.
EDIT:
For "Warning ResourceTag larger than Field (Tag: 64 bits, Field: 32 bits)" simply change Dword to Qword.
EDIT 2:
For "Not all control paths return a value (_HID)" change:
If (TCMF) {}
To:
If (TCMF)
Return(Zero)
For "Error _HID suffix must be all hex digits (GH)" change "ABDCEFGH" to "PNP0C15". (Source: http://www.tonycrapx86.com/viewtopic.php?f=14&t=61284)
Good luck.
I changed to (ASUS P9X79 LE 504 BIOS)
If (TCMF)
               Return (0x0201D824)
           Return (Zero)
I believe that is compliant and the errors go away.
My sole remaining warning in my DSDT is: "_REG has no corresponding Operation Region"
From this section:
                Device (EC0)
                   Name (_HID, EisaId ("PNP0C09"))
                   Name (_CRS, ResourceTemplate ()
                       IO (Decode16,
                           0x0062,             // Range Minimum
                           0x0062,             // Range Maximum
                           0x00,               // Alignment
                           0x01,               // Length
                       IO (Decode16,
                           0x0066,             // Range Minimum
                           0x0066,             // Range Maximum
                           0x00,               // Alignment
                           0x01,               // Length
                   Name (_GPE, 0x1E)
                   Name (REGC, Zero)
                   Method (_REG, 2, NotSerialized)  //error shows at this line
                       If (LEqual (Arg0, 0x03))
                           Store (Arg1, REGC)
I there i fixed all the errors. I have attached both .dsl and .aml format.
Thank you! :D
I'm sorry if this is a noob question but why does the "dsl" say "DSDT_No Errors" while the "aml" only says "DSDT"? I get the the dsl is without errors but does that also apply to the aml? (Asking because multishit uses amls)
any change for a H77-D3H (not the "M" model) or these are the same?
Thank you in advance
-= Carpe Noctem =-
Mod for Greece on all other sites, check me out
I'm curious as well. Has anybody used this edited DSDT with the not-M H77-D3H (or is it the same like SomniusX suggests?)
And if so, has it solved any specific issues for anybody? (I would like to have my USB-3 ports recognize none-USB-3 devices and working vga/dvi mobo ports e.g.)
I'm interested in it too.
I cannot find DSDT for my GA-Z77-D3H with F16 Bios.
Will it work with DSDT for F14 bios? I've already find it but i'm afraid to try it on my Hackintosh.
