Hi,
is it possible to create a DSDT patch that changes the product ID for an USB stick?
I have a Pinnacle DVB tuner DVB-T PCTV 2000e and I wish to use it with Elgato EyeTV. Their software has full support for the PCTV 2001e which, AFAIK, is the same device that I own just with a different product ID.
VID PID
2000e 2304 022c
2001e 2304 0229
I wish to use DSDT to change the Product ID of my 2000e device to the 2001e one, from 022c to 0229. Can I do that with a DSDT patch? And how? I have been looking for it on several forums, but, so far, I have only found patches that change IDs for internal components, not for external USB sticks.
Thanks in advance,
Alberto
