Hello ,
My Specs:
CPU: Intel Core i5-10400 @2.90GHZ
GPU: AMD RX560 4GB
Motherboard: GigaByte B460M ELITE
BIOS: F2
RAM: 16GB DDR4 2666MHZ 2X8GB
Storage: SSD HEORIADY HX-001 512G
Sound: ALC1200 ( Hardware ID VEN_10EC&DEV_0B00 )
Network: intel  Ethernet connection i219-V
Boot app: Opencore 0.60
System: Win10+Mac
I had been successful installed Catalina 10.15.7 via OpenCore 0.60 with EFI File ( Opencore 10th Gen installation ) .
But i got some problems . Maybe you could give me some help to have a fully functional hackintosh .
Problems Description:
1. ALC1200 sound can't work
2. Intel network can't work for i219-V . i had been use interMausiEthernet.kext file .
3. Can't adjust screen brightness.
attachment is  config.plist file.
result files after run RunMe.APP :https://mega.nz/file/7MUX3SST#83VUK3QjnEGYaS24C6P3qMw3-GbXRKDJ9_3qPABOAtU
config.plist.zip
u need use only my folder and no merge
Check RebaseRegions
enjoy
