[Catalina] GigaByte Z390 AORUS PRO / i5-9600K / 580 XT [Not fully Working]
Hi, Mald0n .
You have  patched my DSDT  Almost everyone is working fine.Gratefull.
I got some minimal issues. Maybe you could give me some help to have a fully funtional hackintosh.
My Specs:
  • CPU : Intel® Core™ i5-9600K @3.7GHz
  • GPU : SAPPHIRE RADEON RX 580 8GB
  • Motherboard : GIGABYTE Z390 AORUS PRO (BIOS F12d)
  • RAM :  Ballistic Crucial 16GB (2x8GB) DDR4 3600MHz
  • NVMe : SABRENT 1TB NVMe M.2 @3.0 x4(boot MacOS)
  • CPU Cooler : Corsair Hydro H115I Pro
  • PSU : ThermalTake R2 700W
  • Case: Nox Hummer Nova
Model Identifier: MacPro7,1
MacOS Catalina 10.15.7
OpenCore 0.6.1
DSDT Patched by Mald0n.
Geekbench 5 Score
Single-Core 1129 / Multi-Core 5634
Metal   50355
OpenCL  45179
Could you help me with this ?
  • Sleep;  Now it´s working but I´ve neeeded to unplug Hydro H115I Pro usb cable .  Maybe is there a workaround to enter in sleep mode with the cable plugged but I don´t know.
  • Annoying message every time a booting  , "Memory Modules Misconfigured" .   I don´t know how to avoid this.
  • No information about FANS , not in "Macs Fan Control app", not in HWMonitor, not in iStats.   I don´t know how to configure this in  OpenCore.
  • Thunderbolt  No information about thunderboldt.  I´m not totally sure if this motherboard support it.
Everything else is working Flawlesly.
Really grateful for your patience and dedication.
config.plist.zip
Edited by OrbitDock
sleep, set usb cable port to internal with hackintool
memory msg MacProMemoryNotificationDisabler.kext.zip
fans, virtualsmc missing
tbh, is comon in hackintosh
Thank you Mald0n for your response.
- The memorynotificationdisabler work great. That solves the issue.
- Regarding to the usb cable , I suppose that I have to do the usbmapping. If it so still have to do this part.
- "tbh, is comon in hackintosh" :  I really don´t understand this part.
- Regarding to the  VirtualSMC  ,  I got version 1.1.6 enabled , so it´s not missing . I still got no solution to this , but working on it.
Thank you for your comments.
thunderbolt dont appear there but work
