On 10/9/2020 at 4:36 PM, MaLd0n said:
"change alcid but u need reset nvram every reboot" thanks, it finally worked
Please, second monitor or three is posible? How?
Its necessary change number serial to enter in my apple account ?
check if csm is disable in bios/uefi
generate new smbios with serial and delete content folder library/preferences/systemconfiguration
cms is disable, and second monitor no detected.
ok, thanks
u test other video output? check some combinations
after connecting another monitor via HDMI it works, in a couple of days I will test a third monitor.
Thank you so much for everything.
enjoy
