I created my hackintosh with my I7 9700k in the z390 chipset (Gigabyte Mobo)
When I was installing everything occurred just right. Then I finished the setup installing clover and replacing the Clover Folder in the EFI partition.
Now when I try to boot up my Hackintosh it glitches the video and freezes
If I boot my flashdrive again I'm able to enter MacOs with no problem. So I guess I'm doing something wrong on the EFI installation
Also I'm using a RTX 2080 Super wich I know is not supported and I want to know if is there a way to disable my NVidia GPU and enable My intel UHD 630 graphics (built-in with my i7 9700k)
use usb2 port and use -wegnoegpu and -igfxvesa
