gtxruan Posted October 5, 2020 Posted October 5, 2020 Hey guys. So, I have a GTX 1080, and the following display setup: HDMI: SAMSUNG 50" 4K DisplayPort 1: G2460 PF HERO 24 144 DisplayPort 2: DELL 23.5" My issue: I am currently using AppleALC with Lilu+Whatevergreen kexts on OpenCore. I want my HDMI Samsung 50" 4K display to be the main audio source if it is connected. But, my Displayport 1 device, HERO G2460 PF, also has build-in Audio. Whenever I boot my hackintosh, it only shows under sound devices the G2460 PF hero monitor, instead of showing both HDMI and Displayport audio devices. To fix it, I have to boot my hackintosh without my monitor plugged in the displayport, then it shows "SAMSUNG" under audio devices, then I can plug my monitor again. I would like to be able to show both HDMI and DisplayPort devices there under sound devices if they are both attached,so I can always select samsung, or completely disable the G2460PF hero builtin audio detection, and only leave the SAMSUNG there. Are there any ideas on how to fix it to show both audio devices or what I can do? If I have a headset plugged in it will perfectly show the SAMSUNG + Headset audio, but will never show the monitor. And if I boot my hackintosh with monitor plugged, it will show G2460PF + Headset, but not Samsung. I don't want to use the displayport monitor display device, only the hdmi so i don't have to keep removing the displayport cable then plugging in again. Any ideas?
gtxruan Posted October 5, 2020 Author Posted October 5, 2020 (edited) UP attached ioreg. please help, I don't want to always have to unplug my displayport monitor before powering my hackintosh just to make HDMI audio work :C i can't make show both displayport (monitor) and hdmi (tv) devices on audio devics. it shows only one or another in the audio device picker. i want to show both, to be able to select always my TV as audio device, or disable completely the audio from my displayport monitor, which I am searching like crazy but can't find anything. i installed in two HDs, one using OpenCore other using Clover, but no success at all in any of those. ioRegExport.7z Edited October 5, 2020 by Fullday Work
Administrators MaLd0n Posted October 5, 2020 Administrators Posted October 5, 2020 need read a applealc docs. i think have a patch for that -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
gtxruan Posted October 5, 2020 Author Posted October 5, 2020 Would you mind sharing the link of the patch with me? I am literally trying to fix this non stop and have tried so many things. I went to sleep 4am three days in a row trying to fix hehe. Also I'm from Brazil so if you want we can speak portuguese.
Administrators MaLd0n Posted October 5, 2020 Administrators Posted October 5, 2020 i dont have this link but people use kexts to patch to solve it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
gtxruan Posted October 5, 2020 Author Posted October 5, 2020 Sem ideia então infelizmente, já procurei por tudo e tentei de tudo que é coisa, tanto em clover quanto opencore, várias configs, nada funciona infelizmente. Obrigado mesmo assim, o jeito é ficar desligando monitor antes de ligar o pc
