Errors when starting: "OCS: no schema..."
Good morning,
When I start the PC, just before the opencore boot screen, I get the following messages.
OCS: no schema for Force at 3 index, context <kernel>
OCS: no schema for DisableLinkeditJettison at 6 index, context <Quirks>
Everything works perfectly, but I'm pissed off by those 2 messages.
I have searched the internet and I can't find any information.
I would appreciate a little guidance or how to fix them to make them perfect.
Thank you very much.
what oc version u use?
compile last and check changes for fix in config.plist
Good morning, thank you for answering.
I use the version you have in your OpenCore tutorial "OpenCore Premade EFI Folders" for AMD.
I will do what you say.
U just need a correct config for ur opencore version
every update devs add/remove some configs and we need change in our config.plist
