Special problem with oc 0.6.1 on bigsur
Hello everyone,
I had a special problem installing BigSur with OpenCORE.
When I run the MacOS installer
r/hackintosh - Special problem with bigsur
An error occurred on the following image,then computer reboot by itself.
PS:The same EFI(OC 0.6.1 kext was updated) file works perfectly at 10.15.6, but bigsur doesn't.
Computer configuration
cpu:I5 8500
main board:B360M
Hard disk drive:HDD
Here is my EFI file
EFI.zip
Edited by jun zhou
reset nvram
21 minutes ago, MaLd0n said:
reset nvram
Yes.
I had reset.
1 hour ago, MaLd0n said:
reset nvram
Do you mind check my EFI file for me? Thank you very very very much.
Edited by jun zhou
On 9/30/2020 at 2:42 AM, Richard Milciades Agramonte Santiago said:
I need help, I have done everything and I do not know how to get there with this problem I have added the EFI folder please take a look and tell me that I am doing wrong, I would be very grateful for your help.
https://drive.google.com/file/d/1QUCBLkivdc11qo2YrZVU_LgSRHn7AVAr/view?usp=sharingIMG_09072.jpg.zip
Whose EFI folder do you use?
On 9/30/2020 at 12:35 AM, jun zhou said:
Yes.
I had reset.
Did it work by reset nvram?
Edited by tasco11
