GUIDE: How to activate your intel wifi card.
It looked like this was never going to happen but it did!
What's working?
Wifi 2.4 GHz: YES
Wifi 5 GHz: YES
Connect to hidden network: YES
*Bluetooth: YES
* If you use bluetooth with the internet, the connection will slow down.
OpenIntelWireless
FIRST STEP
Check if your card is on the supported list:
https://openintelwireless.github.io/itlwm/Compat.html#gen-1
SECOND STEP
Download the STABLE version
https://github.com/OpenIntelWireless/itlwm/releases
THIRD STEP
Install itwm.kext in the bootloader
FOURTH STEP
Install Client HeliPort, you need it to select networks.
https://openintelwireless.github.io/HeliPort/
FIFTH STEP
For the Bluetooth: https://github.com/OpenIntelWireless/IntelBluetoothFirmware
Reboot
You will notice that an ethernet network has been created in your system preferences, it is your wifi card. Now just enjoy it.
Greet: zxystd, @MaLd0n, @oldnapalm
Edited by Modigliani
  • Like 2
Lenovo 710S i7
Hey. Nice.
