the EFI 300 folder worked on Z270 GAMING K3,Macos Big Sur beta 8 ,  I put my dsdt.aml, used the latest version of Clover Configurator to change the smbios for Imac 18.3 and put the usb patches
everything works very well  :classic_biggrin:
Edited by gerard71
6 hours ago, Сaramel said:
it happens because of the boot file EFI / boot / bootx64.efi how to fix
use full efi folder from first post after u change things like theme etc
Working For Me
I have Asus Strix Z390-E i9- 9900-k WX2100
everything works fine with the exception of my PCI Wi-Fi which is not detected and does not appear on the pci list unlike OpenCore which detects it and makes it run, I sent you a screenshot of my pci list Opencore / Colver so that you can see the differance,
Clover.zip Opencore.zip
On 9/24/2020 at 5:14 AM, MaLd0n said:
Clover start work again with BigSur. Thanks to Jief_MachakSlice and acidanthera team
Download Clover Folder BigSur for Desktop Serie 300
Don't use Clover Configurator, use one good plist editor if you need change things in your config.plist.
Test with one USB stick bootable.
Enjoy!
Well! perfect for you but for me:
issue on
apfs_module_start:2425. and so on..
Any solution ? thanks !!
5 hours ago, djsnake85 said:
Working For Me
look this
https://www.google.com/search?client=firefox-b&sxsrf=ALeKk03RrNpF79wcUryH3J_HsLDialXr2Q%3A1601116668860&ei=_BlvX4OBNM6OrwSe75zwDg&q=intel+wireless-ac+9560+kext&oq=Intel+Wireless-AC+9560+kext&gs_lcp=CgZwc3ktYWIQAxgAMgIIADoHCAAQRxCwAzoECAAQQzoGCAAQFhAeULgPWMYZYP4kaABwAHgAgAFgiAGQBJIBATaYAQCgAQGqAQdnd3Mtd2l6yAEIwAEB&sclient=psy-ab
I use the first efi folder for the reason that if I change the bootx64.efi file, it loads normally, and if the file is in the first folder, then the download happens like this
https://radikal.ru/video/eqYUxXnB9nd
See if they get something out for skylake
On 9/24/2020 at 6:50 AM, Kankon said:
si. usuario misma carpeta EFI CLOVER BS
you can hang your efi
Edited by pepemix40
2 hours ago, pepemix40 said:
for skylake
just configure quirks
4 hours ago, Zsolt Horváth said:
Hi Mald0n
is a experimental clover for now. devs working on that. we need wait
2 hours ago, jay3444 said:
Hii Mald0n
sound like a quirks problem
i upgraded my notebook ivy bridge from catalina 10.15.7 to big sur beta 6 and works perfect , but i can't upgrade to beta 8 , i received a message that is possible only with full installaller
Não
Sim
Use a pasta do primeiro post e faça as alterações necessárias
2 hours ago, MaLd0n said:
Não
Sim
Então @MaLd0n eu fiz as alterações necessárias e subiu no Haswell, tudo corria bem, e dai na ultima etapa da instalação (logo da maça e tempo restante em baixo, faltando 15 minutos reiniciou) ai ao continuar, deu esse erro aqui da foto olha, tal de SIGILL , por favor me ajuda, como proceder? o que pode ser?
config.rar
Edited by bigbotijao
Attach Config.plist
esse problema acontece em muitos hacks. bigsur e os bootloaders pra hack não estão 100%. Ainda tem casos sem solução.
