On 23/12/2020 at 11:23, Oráculo said:
Estou preso aqui!
pic.jpeg.zip
Alguem pra ajudar?
TUF z270 Mark 2 - Intel I7 6700k - EVGA GTX970 - Crucial Ballistix 16gb 3200mhzCrosair 650TXNVME KingSpec 256GB Wifi Bluetooth Intel 8260Creative X-fi Titanium Pci-ex
MaLd0n,
I could able to install big sur but to boot want to replace the file com.apple.telemetry.plugin with high Sierra file , I tried different ways but could not able to do it and faced various errors like read only file system , resource busy. Please can you share any article on the same. searched the forum but could not find the complete article.
just for unsupported hardware. with support we don't need it
21 hours ago, prashant said:
MaLd0n,
Yes my hardware is not supported , but Catalina is working properly so trying to upgrade to big sur.
MaLd0n,
Any idea on how to replace com.apple.telemetry.plugin as my hardware is not supported.
Does anyone have a booting clover EFI 5127+ for HP skylake/520 laptop w/Big Sur.
Does clover's LAPIC fix work for Big Sur or is there a workaround?
Essential to boot Big Sur from preboot?
Is  DSDT necessary?
What is correct csr-active-config?
Do kexts have to be added to S/L/E or L/E to run Big Sur SIP enabled in both clover and Open Core?
Clover 5128 works fine for Catalina but almost immediate KP for Big Sur.
Thanks for any pointers/help.
u dont need specific guide. the "mechanism" is same for all
For instance.  Clover5131 boots Catalina 10.15.7 without issues, but KPs quickly when boo ting Big Sur, even from Preboot.
However, clover boots a fresh install of Big Sur that is not modified, but once, for instance, I change the login graphic, it KPs when booting.
That same Big Sur boots fine with Open Core, including any changes after fresh install.
Why is that?
This is unexplained.
It logically follows thathere must be some particular modification to the config.plist or other component of clover to cause it to boot Big Sur without errors/panics.
The guide appears to be basic but does not appear to address this issue.  That is why I have asked for a working EFI.
Do you have a clover EFI that will boot Big Sur on HP skylake 520/sunrise point 100 laptop?
use debug=0x100 and keepsyms=1 and check what kp
39 minutes ago, Kankon said:
hello am using clover cofelake i9
RestrictEvents.kext.zip
ifnore this warning in memory tab. coimmon with macpro7,1 s mbios
just replays file ? or I need to do something
I did replays and something
Motherboard Asus TUF Z390-PLUS GAMING (WI-FI) CPU 3.6 GHz 8-Core Intel Core i5, Ram 32 GB 3000 MHz DDR4, Graphics : AMD Radeon RX 6700 XT 12 GB OS:MacOS Tahoe 26.0 RC (25A353) SERIE 30, 40 (COOFFELAKE / COMETLAKE
hello friend ,, tell me anyone can install BS with Graphic old nvidia 210 ?
if any please tell me ...
I have successfully installed Catalina in PC ivybridge VGA old nvidia 210, everything went smoothly.
I want to update to Bigsur ..
Please help me..
"Regards"
6 hours ago, dodisendiri said:
old nvidia 210 ?
it's time to change it
On 9/25/2020 at 8:25 PM, djsnake85 said:
Working For Me
I have Asus Strix Z390-E i9- 9900-k WX2100
everything works fine with the exception of my PCI Wi-Fi which is not detected and does not appear on the pci list unlike OpenCore which detects it and makes it run, I sent you a screenshot of my pci list Opencore / Colver so that you can see the differance,
Hi Snake! How can I get working that card? Radeon Pro WX2100 (trough DisplayPort)
 I've searching on the web, some people inject ATI with a fake ID 0x67EF1002 on Clover, I've follow the steps but not works.
black screen before Apple logo :(  I appreciate some help.
;):cap:guitar:whistle;)
