Managed to install BigSur successfully (and painfree) thanks to this guide.
But after the installation on the first boot, I got a lot of errors with "Too many corpses created.".
Don't know if this an alert for a zombie apocalypse or whatever it is...
Tried so many "solutions" around the web and nothing works.
What can I do?
My machine is an Acer Aspire A515-51G / Core i7 7500U / Intel HD620.
zombie-apocalypse.jpg.zip
use preboot entry
3 hours ago, neverday said:
@MaLd0n minha segunda parte da instalação do Big Sur fica travada nesta tela da imagem adicionada!
configure os quirks
@ MaLd0n fiz uma correção dos quirkss, a segunda parte da instalação subiu, mas agora estou com esse KP
Foto 2.zip
Edited by neverday
Maximus VIII Ranger/ RX 580/ i56600k/ Ram 16G 1600
Lenovo IdeaPad 320 15IKB
vc tem de fazer o boot pela entrada preboot
@MaLd0nGrato pela ajuda ate agora, subi a instalação e estou usando a pasta open core serie 10 e 20 aqui do fórum , mas fica congelado nesta tela da foto!
foto 3.zip
Edited by neverday
1 hour ago, erpipas46 said:
¿No ha sido como iniciar o trevo, mas este arquivo opencore é totalmente compatible con meu pc, posso criar um trevo efi a partir de esta pasta?
why not?
some kext or quirks
Use ssdt olarila
Thanks for this. I can never get the Big Sur installation to boot with open core but got it to boot with clover. I don't understand why this happens.
MaLd0n,
I am trying to install mac os big sur on LGA775. during install post apple logo muse and keyboard does not work , bet everything s working properly in catalina. If i use -s clover flag for some duration mouse and keyboard works but again same problem. please need your advice/help to overcome the error.
Edited by prashant
it's time to new hardware
  • Thanks 1
I'm stuck here!
pic.jpeg.zip
TUF z270 Mark 2 - Intel I7 6700k - EVGA GTX970 - Crucial Ballistix 16gb 3200mhzCrosair 650TXNVME KingSpec 256GB Wifi Bluetooth Intel 8260Creative X-fi Titanium Pci-ex
hi, i install Big Sur with clover on "HP Probook 6470b" with i5 3340M and Intel HD4000.
I had to use certain kexts to run the keyboard and other things, but the performance is pretty good.
The only problem I have, which doesn't allow me to add kexts to S / L / E, is that I can't disable SIP.
I have used clover configurator and modified in RT variables, the value of CSRACTIVECONFIG, and with the value 0x3E7 I always get unknown status, I have tried with other values, but none have worked. I have also tried disabling SIP using the USB installer and terminal with the command / Volumes / MacHDD / user / bin / csrutil disable, but after rebooting does not work.
So i'm stuck ?
Problem image.zip
