ASUS Zenbook 15 10th gen- weird problem with hack.
Hello. I own this Zenbook 15 https://www.asus.com/Laptops/ASUS-ZenBook-15-UX534FAC/specifications/ with i5-10210u cpu, and try install Catalina on it based on Dortania Comet Lake laptop guide. Everytime i boot verbose, everything load perfectly, when graphics should start it starts, apple logo shows with progress bar but it stuck here. One time i got installator booted and install Catalina, then one time it boot to desktop (i dont know how this possible really, same config), then second boot to installed macos stuck apple logo (?) and now everytime it stuck here with progress bar, crazy? read more, i have got an idea to type password on stuck apple logo and hit enter, then i see cursor of mouse, i try pressing some keys and i find when i press F11 desktop shows, then when i try open some app, desktop disappears and apple logo shows again.... i know this sounds like im on lsd or some {censored}, thats why i record this and attach my EFI too. I hear this can be something with memory. In this zenbook RAM is soldered :/. Pls look at this mayby someone have similar issues.
EFI https://wetransfer.com/downloads/c3a3ac93833e5ec7bcc481a3ed7349c020200920230813/f95513
VIDEO https://wetransfer.com/downloads/6a017be4105a99e7b2d88a22381d3e4420200920224002/b5b296
u can use it if need. if u remove battery plugin virtualsmc the problem is gone xD
Hello again, im trying enable audio and trackpad on this laptop, codec is ALC249, i try all layouts, on some only mic is working, no sound, I try dumping dsdt and patching HPET, IRQ, via Dortania guide, but this also don't make change, only mic is working. About trackpad, I try gpi0, no luck, xosi with rename no luck too. I attach my dsdt, dumps from linux and current config. Thanks:).
https://we.tl/t-4FjoFWuLif
As i said, i try all layouts for alc249 provided by github resources, no luck, 21 seems to be best layout coz mic working on it but No sound from speakers. I think i need add new layout for applealc by creating new XML from my codec. Can u help me with this?
