help finalcut and adobe premiere crashing
hi everyone, i have succeeded instaling catalina 10.15.6 on my pc. everything work except everytime i open finalcut pro or adobe premiere it keep crashing, i open chess are also crash but when i'm opening other software just to test like cinebench its work perfectly
i'm attaching my eror report from final cut and also this is the sendme files from runme.app
can anybodyhelp me?
my specs is
motherboard: ASROCK B460M PRO4
Processor: Intel 10400
GPU: Sapphire Radeon RX590 8GB
thank you
eror report.zip
use iMacPro1,1 or MacPro7,1 smbios
hai Mald0n, i have change the smbios but still no change, chess, finalcut and premiere are still not working
but i found out that when i'm turning off my intel IGPU everythings works fine.
are there's possibly some kext that i miss? i want to keep my IGPU active
if u use internal graphics enable need use these properties
-Cometlake(10th Gen)
IntelGFX 0x3E928086
ig-platform-id 0x3E920003
7 hours ago, ed kur said:
can you tell me how to i apply this?
devices properties
Quote
            <dict>
                <data>AwCSPg==</data>
                <key>device-id</key>
                <data>kj4AAA==</data>
            </dict>
