alepartt Posted May 13, 2012 Posted May 13, 2012 Hi everybody,I tried to apply FN Keys patch for Sandy Bridge to my dsdt but result an error.Please help me auto-patcher error.tiff
Cassio Posted May 13, 2012 Posted May 13, 2012 Don't use Auto-Patcher to apply individual patches, use DSDT Editor instead. You also need to apply the DTGP patch. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
alepartt Posted May 13, 2012 Author Posted May 13, 2012 hi cassio,I apply both Patches with dsdt editor I saved in extra but nothing change,I'm still without fn keys .How do I know if my dsdt file is working?
Cassio Posted May 14, 2012 Posted May 14, 2012 Check bdmesg output, you should see Read HFS+ file: [hd(x,y)/Extra/DSDT.aml] xxxxx bytes. You may need specific PS/2 kext to have working fn keys. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
alepartt Posted May 14, 2012 Author Posted May 14, 2012 how I check bdmesg output?sorry I'm not expert.For keyboard and touchpad i tried many kexts but no luck.Is it impossible to make them work by DSDT?ty very much
Cassio Posted May 14, 2012 Posted May 14, 2012 Don't need to be an expert, just run command in terminal, it's installed with Chameleon. You will always need working PS2 kexts, it won't work just with a patch in DSDT. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
alepartt Posted May 18, 2012 Author Posted May 18, 2012 which is the correct command in the terminal?bdmesg output result command not found.The last question:which patch for speed step can I apply for my sandy bridge I3 2350m? ty
Cassio Posted May 18, 2012 Posted May 18, 2012 Then you don't have the command installed, it comes in Chameleon official package. For SpeedStep you have to patch AICPM http://Olarila.com/forum/viewtopic.php?f=9&t=1003 You may need to patch DSDT too (read under "power management") http://Olarila.com/forum/viewtopic.php?f=19&t=634 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
alepartt Posted May 19, 2012 Author Posted May 19, 2012 hola Cassio,I have Chameleon_2.1svn_r1820_trunk_10.8.pkg.How is possible the command is not installed?This means that DSDT is not working? maybe I should choose some option in the installation ad hoc of Chameleon?this version of Chameleon works in 10.7.3?ty
alepartt Posted May 24, 2012 Author Posted May 24, 2012 what do u think about this warning?8109 not all control paths return a value (SX45) -and the line is :Method (SX45, 0, NotSerialized) bye
alepartt Posted May 24, 2012 Author Posted May 24, 2012 hi cassio,have the bdmsg output report changing boot loader.Can you check it please and tell me what do you think about? Last login: Thu May 24 19:20:13 on console host-78-12-112-63:~ ale$ bdmesg output Chimera 1.9.2 (svn-r1394) [2012-05-03 11:45:22] CPU: Brand String: Intel® Core i3-2350M CPU @ 2.30GHz CPU: Vendor: 0x756e6547 CPU: Family / ExtFamily: 0x6 / 0x0 CPU: Model / ExtModel / Stepping: 0x2a / 0x2 / 0x7 CPU: Number of Cores / Threads: 2 / 4 CPU: Features: 0x000002ff CPU: TSC Frequency: 2294 MHz CPU: FSB Frequency: 99 MHz CPU: CPU Frequency: 2294 MHz CPU: Minimum Bus Ratio: 8 CPU: Maximum Bus Ratio: 23 CPU: Current Bus Ratio: 23 Attempting to read GPT Read GPT Reading GPT partition 1, type C12A7328-F81F-11D2-BA4B-00A0C93EC93B Reading GPT partition 2, type 48465300-0000-11AA-AA11-00306543ECAC Reading GPT partition 3, type 48465300-0000-11AA-AA11-00306543ECAC Reading GPT partition 4, type EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 HFS signature was not present. HFS signature was not present. Read HFS+ file: [hd(0,2)/Extra/org.chameleon.Boot.plist] 638 bytes. Invalid mach magic 0x2 Module 'Symbols.dylib' by 'Chameleon' Loaded. Description: Chameleon symbols for linking Version: 0 Compat: 0 Read HFS+ file: [hd(0,2)/Extra/Themes/Default/theme.plist] 2798 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/background.png] 966 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/logo.png] 10718 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_generic.png] 22700 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_generic_o.png] 22748 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_hfsplus.png] 25968 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_hfsplus_o.png] 25971 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_hfsraid.png] 26603 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_hfsraid_o.png] 26565 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_ext3.png] 25554 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_ext3_o.png] 25561 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_fat.png] 24399 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_fat_o.png] 24429 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_fat16.png] 5375 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_fat32.png] 5375 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_ntfs.png] 27227 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_ntfs_o.png] 27197 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_cdrom.png] 23564 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_cdrom_o.png] 22930 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_selection.png] 454 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_scroll_prev.png] 4566 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/device_scroll_next.png] 4381 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/menu_boot.png] 182 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/menu_verbose.png] 182 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/menu_ignore_caches.png] 182 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/menu_single_user.png] 182 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/menu_memory_info.png] 180 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/menu_video_info.png] 180 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/menu_help.png] 180 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/menu_verbose_disabled.png] 187 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/menu_ignore_caches_disabled.png] 187 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/menu_single_user_disabled.png] 187 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/menu_selection.png] 236 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/progress_bar.png] 349 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/progress_bar_background.png] 179 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/text_scroll_prev.png] 632 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/text_scroll_next.png] 650 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/font_console.png] 3499 bytes. Read HFS+ file: [hd(0,2)/Extra/Themes/Default/font_small.png] 5525 bytes. Read HFS+ file: [hd(0,2)/Library/Preferences/SystemConfiguration/com.apple.Boot.plist] 232 bytes. Read HFS+ file: [hd(0,2)/Extra/org.chameleon.Boot.plist] 638 bytes. Read HFS+ file: [hd(0,2)/System/Library/CoreServices/SystemVersion.plist] 478 bytes. Loading Darwin 10.7 Loading kernel cache /System/Library/Caches/com.apple.kext.caches/Startup/kernelcache Read HFS+ file: [hd(0,2)/System/Library/Caches/com.apple.kext.caches/Startup/kernelcache] 4096 bytes. Read HFS+ file: [hd(0,2)/System/Library/Caches/com.apple.kext.caches/Startup/kernelcache] 11788783 bytes. ACPI table not found: DSDT.aml No DSDT found, using 0 as uid value. Using PCI-Root-UID value: 0 Intel Intel HD Graphics 3000 Mobile [8086:0116] :: PciRoot(0x0)/Pci(0x2,0x0) LAN Controller [10ec:8136] :: PciRoot(0x0)/Pci(0x1c,0x1)/Pci(0x0,0x0) Setting up lan keys Read HFS+ file: [hd(0,2)/Extra/smbios.plist] 485 bytes. SMBus CmdReg: 0x3 Scanning SMBus [8086:1c22], mmio: 0xf7e05004, ioport: 0xf040, hostc: 0x1 SPD[0] (size): 146 @0x50 Slot: 0 Type 24 4096MB (DDR3 SDRAM) 1333MHz Vendor=Hynix Semiconductor PartNo=HMT351S6CFR8C-H9N0 SerialNo=13A1318F SPD[0] (size): 255 @0x51 SPD[0] (size): 255 @0x52 SPD[0] (size): 255 @0x53 SPD[0] (size): 255 @0x54 SPD[0] (size): 255 @0x55 SPD[0] (size): 255 @0x56 SPD[0] (size): 255 @0x57 Type: 218, Length: 251, Handle: 0xda00 Type: 218, Length: 59, Handle: 0xda01 Type: 4, Length: 42, Handle: 0x4 ProcessorInformation: socketDesignation: CPU 1 processorType: 3 processorFamily: 0xCE manufacturer: Intel processorID: 0x206A7 processorVersion: Intel® Core i3-2350M CPU @ 2.30GHz externalClock: 99MHz maximumClock: 2294MHz currentClock: 2300MHz serialNumber: To Be Filled By O.E.M. assetTag: To Be Filled By O.E.M. partNumber: To Be Filled By O.E.M. Type: 7, Length: 19, Handle: 0x5 Type: 7, Length: 19, Handle: 0x6 Type: 7, Length: 19, Handle: 0x7 Type: 8, Length: 9, Handle: 0x8 Type: 8, Length: 9, Handle: 0x9 Type: 8, Length: 9, Handle: 0xa Type: 8, Length: 9, Handle: 0xb Type: 8, Length: 9, Handle: 0xc Type: 8, Length: 9, Handle: 0xd Type: 8, Length: 9, Handle: 0xe Type: 9, Length: 17, Handle: 0xf Type: 9, Length: 17, Handle: 0x10 Type: 11, Length: 5, Handle: 0x12 Type: 12, Length: 5, Handle: 0x13 Type: 21, Length: 7, Handle: 0x1c Type: 22, Length: 26, Handle: 0x1d Type: 32, Length: 20, Handle: 0x1e Type: 27, Length: 12, Handle: 0x20 Type: 28, Length: 20, Handle: 0x21 Type: 176, Length: 5, Handle: 0xb000 Type: 177, Length: 12, Handle: 0xb100 Type: 209, Length: 12, Handle: 0x25 Type: 210, Length: 12, Handle: 0x26 Type: 211, Length: 13, Handle: 0x27 Type: 212, Length: 57, Handle: 0x28 Type: 217, Length: 8, Handle: 0x2a Type: 219, Length: 11, Handle: 0x2b Type: 220, Length: 22, Handle: 0x2c Type: 221, Length: 19, Handle: 0x2d Type: 222, Length: 16, Handle: 0x2e Type: 16, Length: 15, Handle: 0x14 Type: 20, Length: 19, Handle: 0x16 Type: 17, Length: 28, Handle: 0x17 MemoryDevice: deviceLocator: DIMM_B bankLocator: BANK 2 memoryType: DDR3 memorySpeed: 1333MHz manufacturer: Hynix Semiconductor serialNumber: 13A1318F assetTag: Not Specified partNumber: HMT351S6CFR8C-H9N0 Type: 19, Length: 15, Handle: 0x18 Type: 13, Length: 22, Handle: 0x2f Type: 216, Length: 9, Handle: 0x29 Type: 0, Length: 24, Handle: 0x0 BIOSInformation: vendor: Apple Inc. version: multishit.tonycrapx86.com releaseDate: 11/06/2009 Type: 2, Length: 15, Handle: 0x2 BaseBoard: manufacturer: Apple Inc. product: Mac-94245B3640C91C81 version: A03 serialNumber: .1V4BQR1.CN70166248017N. assetTagNumber: ?? locationInChassis: To Be Filled By O.E.M. boardType: 0xA Type: 3, Length: 21, Handle: 0x3 SystemEnclosure: manufacturer: Dell Inc. type: 8 version: Not Specified serialNumber: 1V4BQR1 assetTagNumber: ?? Type: 1, Length: 27, Handle: 0x1 SystemInformation: manufacturer: Apple Inc. productName: MacBookPro8,1 version: 1.0 serialNumber: C02F93FQDH2G uuid: 44454C4C-5600-1034-8042-B1C04F515231 wakeupReason: 0x6 skuNumber: To be filled by O.E.M. family: MacBook Pro Type: 208, Length: 12, Handle: 0x24 Type: 10, Length: 6, Handle: 0x11 Type: 17, Length: 28, Handle: 0x15 MemoryDevice: deviceLocator: DIMM_A bankLocator: BANK 0 memoryType: DDR3 memorySpeed: 1333MHz manufacturer: N/A serialNumber: N/A assetTag: 01113400 partNumber: N/A Type: 131, Length: 6, Handle: 0xda01 AppleProcessorType: ProcessorType: 0x901 Type: 132, Length: 6, Handle: 0xda02 AppleProcessorBusSpeed: ProcessorBusSpeed (QPI): 0.1GT/s Type: 127, Length: 4, Handle: 0xda03 Customizing SystemID with : 44454c4c-5600-1034-8042-b1c04f515231 ACPI table not found: DSDT.aml ACPI table not found: SSDT.aml FADT: Restart Fix applied! Found ACPI CPU: CPU0 Found ACPI CPU: CPU1 Found ACPI CPU: CPU2 Found ACPI CPU: CPU3 Found ACPI CPU: CPU4 Found ACPI CPU: CPU5 Found ACPI CPU: CPU6 Found ACPI CPU: CPU7 SSDT with CPU C-States generated successfully P-States: min 8, max 23 Number of P-States Generated: 16 SSDT with CPU P-States generated successfully RSDT: Added 2 SSDT table(s) FADT: Restart Fix applied! Added 2 SSDT table(s) into XSDT Starting Darwin x86_64 Boot Args: boot-uuid=6C25770C-0B4B-3C57-84F2-BB4BA0869552 rd=*uuid npci=0x3000 darkwake=0 host-78-12-112-63:~ ale$ bdmesg output
Cassio Posted May 24, 2012 Posted May 24, 2012 ACPI table not found: DSDT.aml It did not find DSDT.aml in /Extra. Don't worry about the warnings. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
alepartt Posted May 24, 2012 Author Posted May 24, 2012 I have dsdt.aml in extra I extract it with dsdt-editor patched and saved there,and with it have a KP and before an inscription that says something like this:pc root uid value wasn't found use 0 if you want it be 1 use -pcruit flag.If I run windows and delete by macdrive the dsdt.aml mac restart.
Cassio Posted May 24, 2012 Posted May 24, 2012 Then there must be something wrong in that file. For some laptops you can't fix compilation errors or it won't work, you have to run iasl in terminal to compile with errors (or use iaslMe). -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
alepartt Posted May 24, 2012 Author Posted May 24, 2012 I tried to use iaslme but can't understand what it do.Have to extract dsdt in dsdt-editor save as DSDT.dsl drop in iaslme and: ASL Input: /Users/ale/Desktop/DSDT.dsl - 9799 lines, 322856 bytes, 3938 keywords Compilation complete. 11 Errors, 131 Warnings, 5 Remarks, 6 Optimizations All done. Enjoy ... then what I have to do?
Cassio Posted May 24, 2012 Posted May 24, 2012 Apply patches in DSDT Editor, save as DSL (don't fix compilation errors), drop DSL on iaslMe, it should generate AML ignoring errors. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
alepartt Posted May 24, 2012 Author Posted May 24, 2012 ok seems like something change: ACPI table not found: SSDT.aml FADT: Restart Fix applied! FADT: Using custom DSDT! Found ACPI CPU: CPU0 Found ACPI CPU: CPU1 Found ACPI CPU: CPU2 Found ACPI CPU: CPU3 Found ACPI CPU: CPU4 Found ACPI CPU: CPU5 Found ACPI CPU: CPU6 Found ACPI CPU: CPU7 SSDT with CPU C-States generated successfully P-States: min 8, max 23 Number of P-States Generated: 16 SSDT with CPU P-States generated successfully RSDT: Added 2 SSDT table(s) FADT: Restart Fix applied! FADT: Using custom DSDT! Added 2 SSDT table(s) into XSDT Starting Darwin x86_64 Boot Args: boot-uuid=6C25770C-0B4B-3C57-84F2-BB4BA0869552 rd=*uuid npci=0x3000 darkwake=0 MacBook-Pro-di-ale:~ ale$ what do u think?ACPI table not found?
Cassio Posted May 24, 2012 Posted May 24, 2012 Looks like DSDT.aml was loaded now. Maybe the patches you applied didn't make a difference. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
alepartt Posted May 24, 2012 Author Posted May 24, 2012 ACPI table not found: SSDT.aml is not important?Yes maybe the pach for fn keys don't work
