Hello,
Like the title says, having an issue with my current hackintosh setup. Every time it boots up all is working fine and right when it gets to the log in screen, signal cuts out. In order the get the screen back up I have to unplug and reconnect my HDMI cable. I've tried another HDMI cable, also DVI-D cable, still same issue. Tried changing the SMBIOS of the setup multiple times through Clover, no luck. Tried looking through the forums to see if I could find any solution. with no such luck either. Any help in the right direction would be really appreciated. New to all of this, apologies if I don't understand something immediately or if this is an easy fix I should've solved on my own.
Specs
Clover w/Catalina 10.15.4
Gigabyte B365M DS3H
Intel i3 8100
8GB Ram
No dGPU
Fenvi T919 (for wifi and bluetooth)
Triple Boot (Windows, Ubuntu, macOS; Each on their own SSD)
u try with igfxonln=1 bootarg?
check a hackintool for one good video patch
Wow... thank you so much, that simple bootarg fixed the issue. I wish I had known it was that simple. Thanks again I really appreciate it.
Enjoy!
