HP Probook 640 G1 Mojave Battery icon and brightness issue
Hello Hackintoshers, I've successfully installed the MacOS Mojave on my HP ProBook 640 G1 but I have 3 issues.
1. The battery icon/percentage is not showing
2. Brightness not working (I'm guessing it got to do with the battery bar also. Seems it's recognized as a desktop)
3. I get the error "The CMOS checksum is invalid" whenever I shutdown or reboot my PC (attached an image of it)
I've tried fixing the battery by patching the DSDT file but wasn't successful
1. The Wifi will not working properly its don't show a WiFi icon
2. Bluetooth will not working
Quote
<dict>
                <key>Comment</key>
                <string>RTC fix to stop Post Error</string>
                <key>Count</key>
                <integer>0</integer>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>RwFwAHAAAQg=</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <key>OemTableId</key>
                <data></data>
                <key>Replace</key>
                <data>RwFwAHAAAQI=</data>
                <key>ReplaceMask</key>
                <data></data>
                <key>Skip</key>
                <key>TableLength</key>
                <key>TableSignature</key>
                <data></data>
            </dict>
