Intel® Core™ i3-2328M CPU @ 2.20GHz × 4 will hardware compatible for installing Hackintosh
Hello,
I've HP laptop and would like to install Hackintosh, which Hackintosh compatible for my laptop. Below are my laptop specs:
Processor: Intel® Core™ i3-2328M CPU @ 2.20GHz × 4
Graphics: Intel® HD Graphics 3000 (SNB GT2)
Memory: 10 GiB
Disk Capacity: 120.0 GB (SSD)
Please confirm Hackintosh will compatibile for all the hardware? especially WiFi?
Awaiting for your reply!
33 minutes ago, MaLd0n said:
Thank you for the update. Will go with High Sierra then. Can you give me the download link along with High Sierra installation steps?
What about the WiFi functionality on High Sierra, will it compatible for my spec?
Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
17 hours ago, MaLd0n said:
Thank you for the download link.
Can I follow the steps mentioned in the article
Right?
If so, I can start High Sierra installation from step 1 to step 6, right? Please confirm.
In step 7- Copy Olarila EFI folder to EFI partition
Which CHIPSET SERIES can I download?
For HD3000 Intel HD Graphics, do I need to download any files?
this igpu is native
17 minutes ago, MaLd0n said:
this igpu is native
Okay, so I just use installation steps from step 1 to step 6, right?
ye
23 minutes ago, MaLd0n said:
ye
Okay, thank you.
Before proceeding the installation of High Sierra, do I need to enable/disable any functions from the BIOS side?
On 9/11/2020 at 7:51 PM, Sam R said:
Okay, thank you.
Hello,
I'm stuck with the installation process, please verify the URL: https://prnt.sc/uh297l
How can I fix it?
I'm waiting!
check if -igfxvesa with last whatevergreen kext solve that for installation
sorry, where i can get this option?
bootargs
1 minute ago, MaLd0n said:
bootargs
do i need to add -igfxvesa after -V in the bootargs, right? if yes, added and booted, but stuck with the same message
I'm waiting for an alternate way :(
please help me :(
please help me :(
Please update me, i'm still waiting
