First I'm newbie..
So i wanna install Catalina olarila and i tried that many times and i failed.. anyone can help me please ..my laptop specs is
Hp probook 450 G2
I5-5200U 2.2ghz up to 2.7 ghz
4Go ram
500Go HDD
And intel 5500 HD ..please help me
check ur embedded controller name
if u have a ec0 name use it
--OPENCORE--
            <dict>
                <key>Comment</key>
                <string>EC0 to EC</string>
                <key>Count</key>
                <integer>0</integer>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>RUMwXw==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <key>OemTableId</key>
                <data></data>
                <key>Replace</key>
                <data>RUNfXw==</data>
                <key>ReplaceMask</key>
                <data></data>
                <key>Skip</key>
                <key>TableLength</key>
                <key>TableSignature</key>
                <data></data>
            </dict>
            <dict>
                <key>Comment</key>
                <string>RTC _STA</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>oAqTU1RBUwE=</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <data></data>
                <key>Replace</key>
                <data>oAqRCv8L//8=</data>
                <data></data>
                <key>Skip</key>
                <data>RFNEVA==</data>
            </dict>
--CLOVER--
                <dict>
                    <key>Find</key>
                    <key>Replace</key>
                    <key>Disabled</key>
                    <false/>
                    <key>Comment</key>
                </dict>
                <dict>
                    <key>Find</key>
                    <key>Replace</key>
                    <key>Disabled</key>
                    <false/>
                    <key>Comment</key>
                    <string>_STA RTC</string>
                </dict>
