Please help me I have Dell Inspiron 15 Processer 1.9 GHz Dual-Core Intel Core i3 Memory    12 GB 1600 MHz DDR3. Intel HD Graphics 2500 1536
INSTLL Big Sur VERSION 11.0 BETA. WIFI NOT WORKING DW1510 WIFI CARD BCM4322 802.11a/b/g/n Wireless LAN Controller: Name: pci14e4,432b Type: Network controller
 Driver Installed: No  MSI: No  Bus: PCI Slot: Internal@0,28,1/0,0 Vendor ID: 0x14e4  Device ID: 0x30613334 Subsystem Vendor ID: 0x102  Subsystem ID: 0x000d Revision ID: 0x0001 mLink Width:  Link Speed: 2.5 GT/s
I did on my config.plist
I use device id like that
DeviceProperties
PciRoot(0x0)/Pci(0x1C,0x1)/Pci(0x0,0x0)
AAPL,slot-name.      Internal@0,28,1/0,0
device-id.                 43a0
device_type            Network controller
model                    BCM4322 802.11a/b/g/n Wireless LAN Controller
Install kext AirPortBrcmFixup with no PlugIns  I delete them
I have anther issues with Audio ALC282 I try all  AudioCodecs
boot-args alcid=13
layout id 3-4-13-22-27-28-29-41-43-51-76-86-127
config.plist.zip AirportBrcmFixup.kext.zip
post one ioreg here
fail
upload in google drive
this device is rp02/pxsx
@abookhaled2000 don't use report button. post here
Just use a device properties for apply this patch
Quote
Method (_DSM, 4, NotSerialized)  // _DSM: Device-Specific Method
                        If ((Arg2 == Zero))
                            Return (Buffer ()
                                 0x03                                             // .
                        Return (Package ()
                            "AAPL,slot-name",
                            "Built In",
                            "built-in",
                            Buffer ()
                                 0x00                                             // .
                            "model",
                            Buffer ()
                                "Broadcom Brcm43xx Wireless Network Adapter"
                            "name",
                            Buffer ()
                                "AirPort Controller"
                            "compatible",
                            Buffer ()
                                "pci14e4,43a0"
                            "device-id",
                            Buffer (0x04)
                                 0xA0, 0x43, 0x00, 0x00                           // .C..
                            "IOName",
                            "pci14e4,43a0",
                            "device_type",
                            Buffer ()
                                "AirPort Extreme"
                            "pci-aspm-default",
                            Buffer ()
                                 0x00                                             // .
dsdt or ssdt ;)
thank you  very much you have been patient with me i will try it tonight because i am at work now if it work i will donated for your organisation i have one more request what about audio i tried many times no luck what i have to do i will send you send me file to check
hi i have questions about wifi card
Broadcom BCM94350ZAE BCM94350 DW1820A 802.11AC 867Mbps NGFF M.2 Bluetooth 4.1 Wireless Card  Dual Band Wifi card network card
if i bay  this one will work with big sur hackintosh.
dw1560 or dw1830
share files there
