Problem with VoodooHDA....maybe? [ SOLVED thanks cassio!!]
Not having major issues with my sound other than the fact that I only seem to get half volume. If I crank it up all the way and turn up the volume on my speakers I get a major drop off in sound quality, it muffles the sound and gets a bit distorted.
I am using my onboard sound chip which is the Realtek ALC887 Codec/High Def Audio/2/4/5,1/7.1-channel.
I tried using the modified voodoo kext you supply here, but the voodoo panel always shows my output as digital. I do not have that feature on this mobo (GA-M68MT-S2). I only have the standard Blue/Head Phones Pink/Microphone Blue/Speaker jacks. Not sure how to fix the volume issue I tried adding the flag VoodooHDAEnableHalfVolumeFix
to my voodooHDA.Kext /info.plist file,but at reboot I lost my sound and the volume icon was grayed out.
Any suggestions would be appreciated.
Now for the stupid question. How do I find out what the PC ID of my audio chip is? I created one for my video card in EFI Studio and added it to my org.chameleon.boot.plist file and got my video card working like a charm, but I can't seem to do the same for my audio chip. There seems to be no option for my audio chip in EFI Studio.
Okay this is the information in my voodoo.HDA.kext/info.plist
VoodooHDA
CFBundleIdentifier
org.voodoo.driver.VoodooHDA
IOClass
VoodooHDADevice
IOMatchCategory
VoodooHDADevice
IOPCIClassMatch
0x04030000&0xffff0000
IOProviderClass
IOPCIDevice
IOUserClientClass
VoodooHDAUserClient
MixerValues
I have no idea if this is the correct string for my onboard chip.
Device 10de:03f0 This is the device ID and Vendor ID for my onboard chip taken from System Info, I looked it up on the PCI Device Repository, but there was no reference to my PCI ID.
It shows the correct chip: Name: MCP61 High Definition Audio
No other information is available for this chip.
Okay I replaced the information in the info.plist using my DEV id and Ven id:
IOPCIPrimaryMatch
0x10de03f0
When I reboot I have no sound and my speaker icon is grayed out. Not sure why but that is the case.
Device ID first
0x03f010de
Device ID first
0x03f010de
lol....yeah I see that...works like a charm!! Thanks ever so much, now my new speaker system will sound perfect! Where can I give a donation that dosen't require Paypal? :mrgreen:
