Pls help - ACPI error about EC0.BAT0
I always get this kind of error about EC0.BAT0 no matter which tutorial I do (e.g. olarila, opencore)
I can't find any solution on the internet. Pls help me :(
https://imgur.com/b552H1c
Attached file: dsdt extracted from my laptop (Lenovo Legion 5 15IMH05H)
P.S. Sorry for asking kinda dumb question, but how can I follow all these turotials on this website without having MacOS installed in the first place? Especially some tasks that require running an app directly on the 'target' machine (like RunMe.app). Currently, I do everything inside a Mac VM.
Thank you
dsdt.dsl
apply a battery patch and check if work. u can ignore it too
https://www.olarila.com/topic/5794-hackintosh-guide-install-macos-with-vanilla-olarila-image-step-by-step-install-and-post-install-windows-linux-or-mac/
Yes. check if have patch for u in rehabman repository
but the problem in installation is not about battery patch. ignore it. u need check what cause that
