Hi there - I recently built a hack running Catalina 10.15.6 with OpenCore 6.0 and everything is working great!!  Except I am having an issue with getting the drivers to load for either of the two 10gig NIC cards that I tried.  Here are the specs on my build:
Motherboard: ASUS WS-X299-SAGE        CPU: Intel i9 10980XE        RAM: 256GB Corsair Vengeance LPX DDR3000 (PC4-24000)
The two NIC cards that I purchase and installed are:  ASUS XG-C100C 10G NIC & Synology E10G18-T1 NIC
Both cards are suppose to be plug and play right out of the box but once in the system, under PCI it list ethernet card but states the driver is not installed.  From my understanding there is a kext patch in OpenCore or Clover that tells the system whether the card is external or internal.  I am running BIOS 2002 and did try the kext patch to no avail.  I did order a SYBA 1 Port AQTiON AQC107 10 Gig NIC and am awaiting for it to be delivered in hopes that it would magically work :-) LOL..
At one point, I thought the issue could be due to Catalina so I did a fresh install of Mojave but it was the same results.
Any help with this would be greatly appreciated.
Thanks,
check with hackintool or dpci manager what chipset these cards work.
and kexts to patch by Mieze don't solve?
Quote
com.apple.driver.AppleEthernetAquantiaAqtion
Find
6275696C 742D696E
Replace
62626262 62626262
Can you please post your efi folder? I am trying to get a good open core config on my sage10. Also I can help you with the nic card problem, both of mine work nativley. Thanks!
