I finally got my HP 250 G10 running macOS Tahoe with working Iris Xe graphics acceleration. It took quite a few attempts, but the laptop now boots with Metal support instead of the basic 7 MB framebuffer.
Hardware and software:
  • HP 250 G10, motherboard 8B34
  • Intel Core i5-1334U
  • Intel Iris Xe 8086:A7A1, revision 04, 80 EUs
  • Internal 1920×1080 display
  • Realtek RTL8852BE Wi-Fi
  • Realtek Bluetooth USB 0BDA:B85D
  • Realtek ALC236 audio codec
  • macOS Tahoe 26.7.2, build 25G332
  • OpenCore 1.0.8, SMBIOS MacBookPro16,2
GitHub: HP-250-G10-OpenCore-Tahoe
What works:
  • Graphics acceleration: macOS reports Metal Supported and 1536 MB dynamic VRAM
  • Internal display
  • Wi-Fi
  • Bluetooth discovery and pairing with my Samsung Galaxy S21
  • Internal speaker output
  • Battery percentage
  • Brightness slider and F2/F3 brightness keys
  • Keyboard and touchpad
  • CPU Turbo Boost — powermetrics reported a 4.6 GHz P-state
The graphics setup uses a custom HP-specific NootedGreen build based on the work by JulioNectar and dssoftx, alongside WhateverGreen and the matching system graphics stack. I used OpenAI Codex to help investigate crashes, adapt the code and build the installers.
The main changes for this machine were the 80 EU / 6 L3 topology and a 60 MiB DVMT correction. The original driver calculation interpreted the HP firmware value as 4032 MiB, which led us to investigate the allocation failures behind the boot panics. With the corrected build, acceleration finally started working.
Remaining issues:
  • The hardware cursor is corrupted. A software-arrow overlay works as a temporary workaround.
  • Closing the lid and entering system sleep does not resume reliably. I currently disable system sleep and use display sleep instead.
  • Bluetooth pairing is confirmed with the S21, but I have not thoroughly tested other profiles or reconnection after sleep.
  • HDMI and external displays are not yet qualified.
  • The internal microphone appears in macOS but produces no input.
The repository contains a sanitized EFI, source patches, component details and installer tools. The EFI alone is not enough: the matching NootedGreen/TGL system graphics stack is also required. This is a reference for this specific laptop, so please generate your own SMBIOS and keep a recovery boot option.
Huge thanks to the upstream developers for making this possible.
For the microphone, IORegistry confirms ALC236 (10EC:0236, revision 0x100002**)** on controller 8086:51CA. I’m using AppleALC 1.9.8 + SimpleHDA 1.0.1 on Tahoe. Audio output works, but the internal mic stays silent with both layout 11 and the HP-oriented layout 55. The internal microphone is selected as the input device and is not muted, but the input meter never moves. Has anyone got the internal microphone working on an HP 250 G10, or could help identify whether it needs different ALC236 pin routing or uses the Intel SST digital-microphone path?
ALC236 on many 13th-gen HP laptops uses a digital microphone array routed through the Intel SST/PCH path rather than a classic analog HDA input. AppleALC layouts 11 and 55 may define speaker/headphone pins correctly but not expose that DMIC endpoint. Check your codec dump and IORegistry for whether the internal mic is an analog pin complex or a DMIC/SST device. If it is DMIC, AppleALC alone likely will not make it work on Tahoe; you would need the correct SST/DMIC routing or a layout with matching pin defaults. Testing a USB mic would at least confirm the rest of the input stack.
