[Guide] Hackintool - Video Patch - Fast and Easy Solution
robnav
CPU: i7-8700k
Motherboard: HP OEM
GPU: iGPU 630
Post by robnav » 14 May 2019, 23:32
Hey guys. I am trying to get my UHD 630 working and nothing works. I tried to follow this and when I booted screen just went black and I had to replace config.plist with my back up to reboot.
I tried this fix recommended by erroruser:
IntelGFX 0x59128086
ig-platform-id 0x59120003
Check InjectIntel
shikigva=60
This did not work and it caused a kernal panic. I think what caused it was adding IntelGFX 0x59128086 as I did not get it with ig-platform-id 0x59120003 and shikigva=60
Any other things that I could be missing?
Post by MaLd0n » 15 May 2019, 02:00
robnav, post ur files
--Run_Me
robnav
CPU: i7-8700k
Motherboard: HP OEM
GPU: iGPU 630
Post by robnav » 15 May 2019, 14:02
MaLd0n,
Here are my files..
Post by MaLd0n » 15 May 2019, 14:14
robnav, try, replace full efi
EFI.zip
robnav
CPU: i7-8700k
Motherboard: HP OEM
GPU: iGPU 630
Post by robnav » 15 May 2019, 14:50
MaLd0n,
I tried to change out the EFI folder completely and got a kernal panic.
Post by MaLd0n » 15 May 2019, 15:15
robnav, add it in device/properties
<key>PciRoot(0)/Pci(0x02,0)</key>
			<dict>
				<key>AAPL,GfxYTile</key>
				<data>
				AQAAAA==
				</data>
				<key>framebuffer-fbmem</key>
				<data>
				AACQAA==
				</data>
				<data>
				AQAAAA==
				</data>
				<data>
				AAAwAQ==
				</data>
			</dict>
robnav
CPU: i7-8700k
Motherboard: HP OEM
GPU: iGPU 630
Post by robnav » 16 May 2019, 00:19
MaLd0n, when you say to add it to the device/properties are do you mean here?
Post by MaLd0n » 16 May 2019, 02:42
robnav, here, remove intelgfx too
robnav
CPU: i7-8700k
Motherboard: HP OEM
GPU: iGPU 630
Post by robnav » 16 May 2019, 14:57
MaLd0n, for some reason I cant add anything to that box. The grey + sign is greyed out.
Post by MaLd0n » 16 May 2019, 14:59
robnav, the format above is for txt app not clover configurator, just open with txt app and add
robnav
CPU: i7-8700k
Motherboard: HP OEM
GPU: iGPU 630
Post by robnav » 22 May 2019, 14:43
MaLd0n, First thank you for all the help you have offered. I would not have a hackintosh if it wasn't for this website and you. The above code didnt work. I am going to install high sierra because I have been reading the UHD 630 works out the box. Going to install it and report back. Hopefully, it goes smooth.
Post by MaLd0n » 22 May 2019, 14:45
robnav, desktop don't need it, just injectIntel solve 90%
JoeValarezo
CPU: intel i7 5500 U
Motherboard: intel
GPU: amd radeon m230
Post by JoeValarezo » 04 Jun 2019, 13:10
HI...I have a problem first i install hackintosh from USB is Ok but I want to boot from the disk where it was installed I get this error
HELP ME, PLEASE
pietralbino
CPU: 17 6700
Motherboard: Asrock
GPU: Nvidia gt730
Post by pietralbino » 29 Jun 2019, 15:53
15 Mar 2019, 13:47
:D
michaelanhvu
CPU: i7-6700k
Motherboard: Gigabyte Gaming G7-Z170
GPU: AMD R9380
Post by michaelanhvu » 20 Jul 2019, 18:58
Skylake, 6700k, g7 z170x, cant create a patch like you. How can i patch this?
Post by MaLd0n » 20 Jul 2019, 19:19
michaelanhvu, [Local Link Removed for Guests]
cachiputi
Donator
Donator
CPU: i5
Motherboard: gb
GPU: nvidia
Post by cachiputi » 07 Aug 2019, 08:18
Hi friend!!
I tried to do it with my i7-4770K (Intel HD4600) but it doesn't create the necessary patch.
It's like it lacks more information, it doesn't work out like in your tutorial.
I guess why I didn't compile Lilu and weather ... ketxs
How can I do it?
Thank you!!
Post by MaLd0n » 07 Aug 2019, 12:59
cachiputi, in ur case just InjectIntel solve, try it
cachiputi
Donator
Donator
CPU: i5
Motherboard: gb
GPU: nvidia
Post by cachiputi » 08 Aug 2019, 08:10
07 Aug 2019, 12:59
Post by MaLd0n » 08 Aug 2019, 13:13
cachiputi, skylake+ only
Return to “Patches and tricks”
