Post by MaLd0n » 28 Jan 2019, 13:03
***The Olarila image is clean, without any mod with Clover bootloader, essentials kexts and patches, ALL inside Clover folder***
Hello ppl, let's start
Consider donating a small sum to help cover the costs of bandwidth, etc. Anything you can provide is appreciated, thanks!
Paypal Link --> [External Link Removed for Guests]
*AMD users have a good support with patches from here*
1- Download Olarila Image
Link --> [Local Link Removed for Guests]
*After Download, extract image
2- Format USB Stick
3a- Burn Olarila Image on MacOS/Windows/Linux with Etcher
*Download Etcher
*Open app and select extracted Image
*Select USB Stick(use 16gb USB stick)
*Burn Image
3b- Burn Olarila image on Windows with Win32DiskImager
*Download Win32DiskImager
1- Format USB Stick
2- Open Win 32 Disk Imager
3- Load Olarila Image
4- Burn
4- Boot from USB
*Use a boot key(Gigabyte is F12, Asus is F8, etc)
*Select Boot MacOS Install from Olarila Image
*Notebooks use config2.plist, press O key in Clover boot screen, go to Configs
*Select config2.plist
5- Format SSD
*Select "Show All Devices"
*Format SSD, use APFS and go to installation
*After installation, boot from USB stick again, use boot key and select your SSD with system installed
6- Start a Post Installation
*Go to Olarila Image/Files folder and run "disablehibernate.command"
and "master-disable.command"
7- Install Clover Bootloader in SSD
*Mobos UEFI
*Mobos Bios
8- Replace Clover folder with Olarila Clover folder
*Download Clover folder for your Chipset
*You can use Olarila.app too
*Replace Clover folder in /Volumes/EFI/EFI
*My suggestion, Install Clover bootloader again after replace Clover folder
*Reboot
9- Fine Tune, DSDT
DSDT (Differentiated System Description Table) is a part of the ACPI specification. It supplies information about supported power events in a given system. ACPI tables are provided in firmware from the manufacturer. A common MacOS problem is missing ACPI functionality, such as: fans not running, screens not turning off when the lid is closed, shutdown, boot fast without any ACPI error or warnings, sata, usb, firewire conflicts, etc. This can stem from DSDTs made with Windows specifically in mind, which can be patched after installation.
*Go to topic "DSDT patch requests" and read instructions, post your files there
*Paste edited DSDT.aml in Clover/Acpi/patched folder
*Reboot
Olarila common patches for one perfect Hackintosh
--DSDT Patches--
-FIX ERRORS AND WARNINGS
-FIX ACPI ERRORS
-REMOVE UNUSED SCOPES / DEVICES
-HIGH PRECISION EVENT TIMER
-SATA SERIE 10 ID
-DMAC
-REMOVE LINES, PROBLEMATIC and UNUSED
-FIX K.P in REBOOT
-NVRAM / REAL TIME CLOCK
-SLPB
-DARWIN / WINDOWS 2015
-XHCI
-PLUGIN TYPE
-HDAS to HDEF
-HDEF
-REAL TIME CLOCK
-ARTC
-IPIC
-TIMR
-SBUS
-MIKEY
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-UAR1
-LAN
-FWHD
-USBX
-PMCR
-PPMC
-XSPI
-GMM
-IMEI
-EC
-PNLF
-ARPT
-GFX0
-NVME
-DTGP
-ACQUIRE MUT0 0XFFFF
-OPERATION REGION GPIO
-MUTEX MUT0 0x00
-EXTERNAL REFERENCES
-UNKNOWNOBJ
-HDMI / HDAU
-FULL RENAMED DEVICES
--Useful Links--
*Audio
*Video
*Laptop Battery
*Brightness Hotkey Remapping
*Cpu Friend
*Hide Volumes / Extra Boot Entries With Clover Config
*VoodooHDA - common problems
*UEFI multi boot with Clover
*How to patch AppleHDA
*Hardware Encoder / Hardware Decoder / Video Processing / HEVC Support
*USB Mojave+
-Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders!
-Donated? Send me one PM-
Sampath007
CPU: i7-8550u
Motherboard: Acer Nitro 515-31
GPU: UHD 620
Post by Sampath007 » 28 Jan 2019, 15:34
:guitar :guitar :guitar :guitar
Post by MaLd0n » 28 Jan 2019, 15:40
Sampath007, :meeting :guitar
erroruser
CPU: i9 9900k
Motherboard: asus z390-a
GPU: rx 590
Post by erroruser » 28 Jan 2019, 16:00
:superman :superman :superman
Asus z390-A, i9 9900k, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, sapphire rx 590, fractal celcius s36
:superman :superman
Yasser Homsi
CPU: Core i5 2400m
Motherboard: Asus
GPU: intel 3000
Post by Yasser Homsi » 28 Jan 2019, 20:16
Hi
I 'm confused my budget about 900$
I wanna a mac computer to start working as ios developer
so I have two choices
1. buy a mini mac with base modal I cant afford more than 900$
2. buy ASUS TUF GAMING FX504GD I5-8300H 8GB with GTX 1050 and install hackintosh on it
I 've experienced hackintosh on my old laptop which has 2th-gen processor but I 've faced many troubles to find kexts
so will Nividia gtx1050 work ?
I wonder if the mother board is compatible ?
what should i buy ?
Post by MaLd0n » 28 Jan 2019, 20:19
Yasser Homsi, [Local Link Removed for Guests]
buy one Gigabyte mobo instead ASRock
Yasser Homsi
CPU: Core i5 2400m
Motherboard: Asus
GPU: intel 3000
Post by Yasser Homsi » 28 Jan 2019, 20:30
@Mald0n
thank for your replay
I would buy a laptop I won't buy a normal pc that will cost me as a laptop
Are there laptops with Gigabyte motherboad ?
how can i know is tuf asus compatible ?
Post by MaLd0n » 28 Jan 2019, 20:34
erroruser, :guitar :guitar :guitar
Added in 1 minute 5 seconds:
Yasser Homsi, No, if u need a nvidia card, u need buy a good laptop without Optimus technology and stay in high Sierra, Mojave don't have support for last Nvidia cards
Yasser Homsi
CPU: Core i5 2400m
Motherboard: Asus
GPU: intel 3000
Post by Yasser Homsi » 28 Jan 2019, 20:44
please help me
so how can i know if tuf asus motherboad is compatible ?
Post by MaLd0n » 28 Jan 2019, 20:46
Yasser Homsi, tuf asus is for desktop, u need a laptop, no?
Yasser Homsi
CPU: Core i5 2400m
Motherboard: Asus
GPU: intel 3000
Post by Yasser Homsi » 28 Jan 2019, 20:57
I need a laptop may be it is available as desktop or laptop
Mojave doesn't support the lastest Nvidia cards that is temporary sitaution unit the developers released a new web driver or permanent ?
can't i count on integrated video card of Intel core i5-8300 as mini mac is coming without separated video ?
the mini mac is coming without separated video card how can that be possible ?
I 've seen gtx 1050 in the url you've jst posted the first reply
Post by MaLd0n » 28 Jan 2019, 21:06
Yasser Homsi, i think is permanent, don't buy it
Yasser Homsi
CPU: Core i5 2400m
Motherboard: Asus
GPU: intel 3000
Post by Yasser Homsi » 28 Jan 2019, 21:38
what about the integrated video card of Intel core i5-8300 with 16bg will work at least 1533mb ?
why can't i count on integrated video card of Intel core i5-8300 as mini mac is coming without separated video ?
how can that be reasonable ?
Post by MaLd0n » 28 Jan 2019, 22:25
Yasser Homsi, yes, work, not a monster performance, but work
pdevonie
Geek
Geek
CPU: i7 8700
Motherboard: B360M
GPU: GT 710 2GB
Post by pdevonie » 28 Jan 2019, 23:06
Eu instalei as kexts whatever + lilu, e mesmo assim minha placa de vídeo não foi reconhecida no High Sierra, será que ela não é mais reconhecida nela? Consegui no máximo até o Sierra. Tenho uma R7 3602GB
Post by MaLd0n » 28 Jan 2019, 23:14
pdevonie, eu nunca usei essa sua placa de vídeo
luky53
CPU: Intel Core i5 Duo
Motherboard: Intel
GPU: NVidia 310
Post by luky53 » 29 Jan 2019, 17:23
28 Jan 2019, 13:03
LENOVO-ThinkCentre M90p: CPU: 3,19 GHz, Intel Core i5, RAM: 8,0GiB, HDD: 500 GiB, SSD: 60 GiB, GPU: NVidia 310, 512 MB, Audio: Realtec ALC 662, Network Intel 82578
DM Gigabit
- OS X Yosemite 10.10. 1
luky53
Motherboard: Intel
GPU: NVidia 310
Post by luky53 » 29 Jan 2019, 18:35
MaLd0n hi,
Made the USB installation according to your instructions, but after a short run I get an error (image).
Can you help me what's wrong?
Thank you.
My Computer:
  - ThinkCentre M900z:  Motherboard: | Skylake,  Chipset Intel Q170 ( Skylake PCH-H ) | CPU: Intel Core i5-6500 Codename Skylake5 Socket H4 (LGA 1151) | GPU: Intel HD Graphic 530 |   Network: | Intel Ethernet Connection I219-LM, Intel Dual band Wireless-AC 8260 AC 2x2 Wifi Adapter| Audio: Realtec ALC286, Intel SKYLAKE PCH-H High Definition | Memory: | 16 GB PC4 DDR4-2400 /PC4-19200 | SSD 256 GB |
pdevonie
Geek
Geek
CPU: i7 8700
Motherboard: B360M
GPU: GT 710 2GB
Post by pdevonie » 29 Jan 2019, 20:40
Tem algum programa que deja para abrir a imagem .raw? Pois só gostaria do EFI da imagem, pois não queria fazer o pen drive bootavel, existe algum programa? Ou algo que eu possa estar vendo as pastas EFI das imagens?
Post by MaLd0n » 30 Jan 2019, 15:25
luky53, what ur hardware?
Added in 26 seconds:
pdevonie, é só renomear .raw pra .dmg e montar
