onemanosx
Post by onemanosx » 01 Jan 2019, 04:01
Disclaimer: This is not meant to be a thorough help guide. In fact, this write up is a simpler way to guide through new hackintoshers without going into details. Read in-depth guide from the established writer Rehabman in his original article here [External Link Removed for Guests].
Note:
1. If you are using virtualsmc instead of fakesmc, then you will need SMCBatteryManager.kext instead of ACPIBatteryManager.kext.
2. You should also remove voodoobattery kext from your system.
3. If you'd like assistance on how to start, you should at least find all the used byte called in your EmbeddedControl. Read the guide below on how to achieve that.
New hackintoshers may not realise that Rehabman's repo may already have patches ready for their laptops. This can be easily accessed by going through RH Github Repo here [External Link Removed for Guests].
Various laptop battery patches available in RH Repo using MacIASL
1. Download acpibatterymanager kext from RH bitbucket site [External Link Removed for Guests]. Place the kext at Clover/kexts/other folder. Reboot.
2. Download a copy of MacIASL app. The app can be found in "Files" folder of Olarila's image USB stick or simply download a release from [External Link Removed for Guests]
3. Open MacIASL app, click the Patch icon on the top section of the app and scroll to [bat] -->Battery Patches.
Click any model on the left pane and you will also see other laptop models, on the right pane where the patch is also compatible with.
Go through each section to see if your laptop model is available.
If you had gone through all the sections and did not find a match, you are then expected to create your own DSDT patches.
How to Start?
In this example, we will use a table attached here
Sample - DSDT.aml.zip
1. Find EC region
OperationRegion (ERAM, EmbeddedControl, Zero, 0xFF)
2. In the ERAM field, search for all bytes more than 8. Thus we will find the list below
SMD0,   32
MBCT,   16,
RCAP,   16,
MBC2,   16,
MBVT,   16,
RCA2,   16,
MBV2,   16,
DBAT,   16,
FRMS,   16,
FRS2,   16,
MDCP,   16,
MBCP,   16,
MBDV,   16,
RSOC,   8,
BTMP,   16,
BASN,   16,
MBDN,   120,
NMON,   16,
CYCL,   16,
3. From the list above, we determine if each integers are being called in the DSDT. Lets look for SMD0 and we will find its not called up in the EC0 region. We will omit this integer from our list.
4. Next we continue to look for the next integer, MBCT and found its called up down the EC0 region.
5. For MBC2, we find it is not called up anywhere else. So we can omit this integer.
Going through all the list, we then find only these integers are being called and in use.
MBCT,   16,
RCAP,   16,
MBVT,   16,
DBAT,   16,
FRMS,   16,
FRS2,   16,
MDCP,   16,
MBCP,   16,
MBDV,   16
Fixing 16-bit registers
Just use the below code format as an example. For MBCT we are "splitting" 16 bits to two 8 bits. The 8 bit renaming is easier to just use the last three alphabets (or first three. Your choice, really). Just make sure the renames do not start with a decimal but an alphabet instead.
So, MBCT will become BCT0 & BCT1. And the resulting format will be as such
into device label EC0 code_regex MBCT,\s+16, replace_matched begin BCT0,8,BCT1,8, end;
As for RCAP will become CAP0 & CAP1 and the resulting code format will be
into device label EC0 code_regex RCAP,\s+16, replace_matched begin CAP0,8,CAP1,8, end;
Do the same for all of our 16 bits findings
We will finally achieve the below codes for the rest of our findings.
into device label EC0 code_regex MBVT,\s+16, replace_matched begin BVT0,8,BVT1,8, end;
into device label EC0 code_regex DBAT,\s+16, replace_matched begin DBA0,8,DBA1,8, end;
into device label EC0 code_regex FRMS,\s+16, replace_matched begin RMS0,8,RMS1,8, end;
into device label EC0 code_regex FRS2,\s+16, replace_matched begin RS20,8,RS21,8, end;
into device label EC0 code_regex MDCP,\s+16, replace_matched begin DCP0,8,DCP1,8, end;
into device label EC0 code_regex MBCP,\s+16, replace_matched begin BCP0,8,BCP1,8, end;
into device label EC0 code_regex MBDV,\s+16, replace_matched begin BDV0,8,BDV1,8, end;
Patching DSDT with 16 bit registers
Open MacIASL, click the Patch tab and paste the codes in the box
When we hit apply, we will find errors when trying to compile the DSDT. This is expected.
What we need to do next is fix these errors individually.
Fixing 16 bit Method
Lets look at the first error
Since we had "split" 16 bit FRMS into two 8 bits RMS0 and RMS1,
we will now need to introduce a standard B1B2 method into our DSDT
into method label B1B2 remove_entry;
into definitionblock code_regex . insert
begin
Method (B1B2, 2, NotSerialized) { Return(Or(Arg0, ShiftLeft(Arg1, 8))) }\n
end;
Next we will manually patch the FRMS error with the code format below
B1B2(\_SB.PCI0.LPCB.EC0.RMS0,\_SB.PCI0.LPCB.EC0.RMS1)
Before
After
Next error also occurs for FRMS
This time round we fix the error using the code format below
B1B2(^^PCI0.LPCB.EC0.RMS0,^^PCI0.LPCB.EC0.RMS1)
After patching
Again, for the rest of the 16 bit integers, we will find the codes below to manually fix our errors. (Manually, because I cannot find a solution to automate the tedious process :? )
FRMS -> B1B2(\_SB.PCI0.LPCB.EC0.RMS0,\_SB.PCI0.LPCB.EC0.RMS1)
FRMS -> B1B2(^^PCI0.LPCB.EC0.RMS0,^^PCI0.LPCB.EC0.RMS1)
FRS2 -> B1B2(^^PCI0.LPCB.EC0.RS20,^^PCI0.LPCB.EC0.RS21)
DBAT -> B1B2(\_SB.PCI0.LPCB.EC0.DBA0,\_SB.PCI0.LPCB.EC0.DBA1)
DBAT -> B1B2(^^PCI0.LPCB.EC0.DBA0,^^PCI0.LPCB.EC0.DBA1)
MDCP -> B1B2(^^PCI0.LPCB.EC0.DCP0,^^PCI0.LPCB.EC0.DCP1)
MBCP -> B1B2(^^PCI0.LPCB.EC0.BCP0,^^PCI0.LPCB.EC0.BCP1)
MBDV -> B1B2(^^PCI0.LPCB.EC0.BDV0,^^PCI0.LPCB.EC0.BDV1)
MBCT -> B1B2(^^PCI0.LPCB.EC0.BCT0,^^PCI0.LPCB.EC0.BCT1)
MBVT -> B1B2(^^PCI0.LPCB.EC0.BVT0,^^PCI0.LPCB.EC0.BVT1)
RCAP -> B1B2(^^PCI0.LPCB.EC0.CAP0,^^PCI0.LPCB.EC0.CAP1)
The Final Step
Add the below standard codes to our DSDT, press Apply and make sure no error in our compile.
(Note: You may need to change EC0 to H_EC or EC depending on your own DSDT)
#utility methods to read/write buffers from/to EC
into method label RE1B parent_label H_EC remove_entry;
into method label RECB parent_label H_EC remove_entry;
into device label EC0 insert
begin
Method (RE1B, 1, NotSerialized)\n
{\n
	OperationRegion(ERAM, EmbeddedControl, Arg0, 1)\n
	Field(ERAM, ByteAcc, NoLock, Preserve) { BYTE, 8 }\n
	Return(BYTE)\n
}\n
Method (RECB, 2, Serialized)\n
{\n
	ShiftRight(Arg1, 3, Arg1)\n
	Name(TEMP, Buffer(Arg1) { })\n
	Add(Arg0, Arg1, Arg1)\n
	Store(0, Local0)\n
	While (LLess(Arg0, Arg1))\n
		Store(RE1B(Arg0), Index(TEMP, Local0))\n
		Increment(Arg0)\n
		Increment(Local0)\n
	}\n
	Return(TEMP)\n
}\n
end;
begin
Method (WE1B, 2, NotSerialized)\n
{\n
    Store(Arg1, BYTE)\n
}\n
Method (WECB, 3, Serialized)\n
{\n
    Store(Arg2, TEMP)\n
    Store(0, Local0)\n
    {\n
        WE1B(Arg0, DerefOf(Index(TEMP, Local0)))\n
        Increment(Arg0)\n
        Increment(Local0)\n
    }\n
}\n
end;
The DSDT is now ready to be placed in Clover/ACPI/Patched folder. Reboot and see if your hard work paid off.
If you face any issues and would like help from others in this community, attach your post with Laptop model and dump files using this app [Local Link Removed for Guests]
If you find this guide useful and would like to contribute your successful patch, just make a post with Laptop model details, patch codes and attach an original DSDT.
To be continued ....
Intel i7-6700HQ, 8GB RAM (UEFI Clover Mojave)
MSI B360 Gaming Arctic
Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Mojave)
onemanosx
Post by onemanosx » 01 Jan 2019, 04:02
Update 3 Jan 2019
Dealing with 32 Bits
Dealing with 32 bits is fairly similar to that of 16 bit. Lets say we have
BTY0,   32,
BTY1,   32,
The standard looking code with look like this
into device label H_EC code_regex BTY0,\s+32 replace_matched begin TY00,8,TY01,8,TY02,8,TY03,8 end;
into device label H_EC code_regex BTY1,\s+32 replace_matched begin TY10,8,TY11,8,TY12,8,TY13,8 end;
And we will have the fix 32 bit method code which looks similar to this
BTY0 - (B1B4(\_SB.PCI0.LPCB.H_EC.TY00,\_SB.PCI0.LPCB.H_EC.TY01,\_SB.PCI0.LPCB.H_EC.TY02,\_SB.PCI0.LPCB.H_EC.TY03), end;
BTY1 - (B1B4(\_SB.PCI0.LPCB.H_EC.TY10,\_SB.PCI0.LPCB.H_EC.TY11,\_SB.PCI0.LPCB.H_EC.TY12,\_SB.PCI0.LPCB.H_EC.TY13), end;
And the Standard Code for fixing 32 bit register
into method label B1B4 remove_entry;
begin
Method (B1B4, 4, NotSerialized)\n
{\n
    Store(Arg3, Local0)\n
    Or(Arg2, ShiftLeft(Local0, 8), Local0)\n
    Or(Arg1, ShiftLeft(Local0, 8), Local0)\n
    Or(Arg0, ShiftLeft(Local0, 8), Local0)\n
    Return(Local0)\n
}\n
end;
Fixing Larger than 32 bits
I was going through my note for an update to fix integers larger than 32 bit, when I realized RH perhaps has the best explanation laid out.
In short, for integers larger than 32 bit, we will need to find each offset values which is the tricky part (HINT: Observe the pattern)
We have these 2 values larger than 32 bits
Field (ERAM, ByteAcc, Lock, Preserve)
                        Offset (0x02), <<--Hex
                        PSTD,   8,
                        Offset (0x18), <<-- HEX
                        SMPR,   8,
                        SMST,   8,
                        SMAD,   8,
                        SMCM,   8,
                        SMD0,   264,
                        Offset (0xA0), <<-- HEX
		        BBAR,   136,
This is how the offset values are attained
                        Offset (0x02),
                        PSTD,   8,
                        Offset (0x18), <<-->> HEX to DEC -->> //24
                        SMPR,   8, // 24 <<-->> DEC to HEX -->>(0X18)
                        SMST,   8, //24+(8/8) = 25 <<-->> DEC to HEX -->>(0X19)
                        SMAD,   8, // 24+(8/8)+(8/8) = 26 <<-->> DEC to HEX -->>(0X1A)
                        SMCM,   8, //24+(8/8)+(8/8)+(8/8)= 27 <<-->> DEC to HEX -->>(0X1B)
                        SMD0,   264, //24+(8/8)+(8/8)+(8/8)+(8/8) = 28 <<-->> DEC to HEX -->>(0X1C) <<--
			Offset (0xA0), //
			BBAR,   136,// (0XA0)
From the above, our offset values for SMD0 and BBAR is achieved by a simple calculation. HINT: Unless specified by an Offset directive, the offset of any register is the offset of the previous register + previous register size
Next, we will rename SMD0 and BBAR to SMDX and BBAX respectively
into device label EC0 code_regex (SMD0,)\s+(264) replace_matched begin SMDX,%2,//%1%2 end;
into device label EC0 code_regex (BBAR,)\s+(136) replace_matched begin BBAX,%2,//%1%2 end;
And the fix method code will look similarly as
SMD0 -  \_SB.PCI0.LPCB.EC0.RECB(0X1C,264)
BBAR -  \_SB.PCI0.LPCB.EC0.RECB(0XA0,136)
That is all on fixing larger than 32 bit integers.
Are you sure the offset values are derived that way?
If you are not yet convinced on how I attained the offset values, you may compare the below calculation and its result with RH's example. I hope its useful for some of our readers.
Field (ECF2, ByteAcc, Lock, Preserve)
       Offset (0x10),
       BDN0,   56,     // (0x10)
       Offset (0x18),
       BME0,   8, // (0x18)
       Offset (0x20),// <<—- Hex to decimal is 32
       BMN0,   32,     // 32 (0x20)
       BMN2,   8,     // 32+(32/8)=36 //result in Dec and convert to Hex —>> (0x24)
       BMN4,   88,    //32+(32/8)+(8/8) = 37 //result in Dec and convert to Hex —>>(0x25)
       BCT0,   128,     //!! 32+(32/8)+(8/8)+(88/8) = 48 //result in Dec and convert to Hex —>>(0x30)
       BDN1,   56,     //!! 32+(32/8)+(8/8)+(88/8)+(128/8) = 64 //result in Dec and convert to Hex —>>(0x40)
       Offset (0x48),
       BME1,   8, //(0x48)
       Offset (0x50),
       BMN1,   32,     // (0x50)>> <<—- Hex to decimal is 80
       BMN3,   8,     // 80+(32/8) = 84 //result in Dec and convert to Hex —>>(0x54)
       BMN5,   88,     // 80+(32/8)+(8/8) = 85 //result in Dec and convert to Hex —>>(0x55)
       BCT1,   128,     //!! 80+(32/8)+(8/8)+(88/8) = 96 //result in Dec and convert to Hex —>>(0x60)
erroruser
CPU: i9 9900k
Motherboard: asus z390-a
GPU: rx 590
[Help Guide] Laptop Battery Indicator - The DSDT Patching Horror
Post by erroruser » 01 Jan 2019, 04:09
:guitar :guitar :guitar :guitar
Asus z390-A, i9 9900k, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, sapphire rx 590, fractal celcius s36
:superman :superman
Sampath007
CPU: i7-8550u
Motherboard: Acer Nitro 515-31
GPU: UHD 620
Post by Sampath007 » 01 Jan 2019, 05:12
:superman :superman
Marvelous
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 01 Jan 2019, 06:11
This patch is needed for showing battery percentage ?
On my laptop battery percentage works without this patch. Should I gain anything by using it ?
onemanosx
Post by onemanosx » 01 Jan 2019, 07:09
mathewgx, why would you need to patch for something that is working? :lol:
No. No benefits at all 8-)
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 01 Jan 2019, 13:05
Ok.
Just thought that it would be something like more accurate for example. And it seemed stranged that mine is working without any battery patch.
onemanosx
Post by onemanosx » 01 Jan 2019, 13:11
01 Jan 2019, 13:05
There is no harm double checking against your DSDT and the guide though.
Post by MaLd0n » 01 Jan 2019, 14:45
:guitar :cap
-Donated? Send me one PM-
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 01 Jan 2019, 15:33
01 Jan 2019, 13:11
That's the strange part.
I don't use dsdt , I use hotpatch with no battery patch at all.
onemanosx
Post by onemanosx » 01 Jan 2019, 15:36
01 Jan 2019, 15:33
When you dont specify DSDT file in Clover/ACPI/Patched, Clover automatically uses your native DSDT for use.
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 01 Jan 2019, 15:53
Oh I see.
Your guides are great.
Wish you make a guide for acpi hotpatching , too. I would like a bit of a help with mine.
onemanosx
Post by onemanosx » 02 Jan 2019, 04:15
01 Jan 2019, 15:53
Wish you make a guide for acpi hot patching , too. I would like a bit of a help with mine.
Thank you. That's very heartwarming to hear :D
Its too wide of a topic to talk about clover's hot patching in one single post and MaLd0n is the best man for it. :mrgreen:
onemanosx
Post by onemanosx » 02 Jan 2019, 11:19
mathewgx, The reason you dont require any patching for battery status is probably due to all the 8 bits count only in your embedded field values. ;)
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 02 Jan 2019, 13:32
I don't have any clue about what you said , but you know better.
onemanosx
Post by onemanosx » 02 Jan 2019, 23:39
02 Jan 2019, 13:32
I am still learning, the reason I know is because I opened up your DSDT from the previous post where you uploaded your send_me file ;)
onemanosx
Post by onemanosx » 05 Jan 2019, 01:40
sarakabir,
Check for battery fix.
sarakabir BATFIX - DSDT.aml.zip
Download kext here [External Link Removed for Guests]
bilal1947
CPU: i3 6th gen
Motherboard: intel
GPU: intel hd 520
Post by bilal1947 » 05 Jan 2019, 07:24
Dear why don't you guys make 2 or 3 video tutorial along with verbal instructions this will educate more instead of pasting above readings will not educate until you will guide exact steps in video.
onemanosx
Post by onemanosx » 13 Jan 2019, 02:32
ziomalex, check battery patch.
ZIOMALEX- BATTERY DSDT.aml.zip
ziomalex
CPU: intel i5-9600k
Motherboard: gigabyte z390 gaming x
GPU: rx570 8gb
Post by ziomalex » 13 Jan 2019, 03:29
do I need to rename it? as I have DSDT.aml patched by mald0n in patched folder
