Hide Volumes / Extra Boot Entries With Clover Config
erroruser
CPU: AMD Ryzen 7 3700X
GPU: Sapphire rx 5700 XT
Post by erroruser » 12 Nov 2018, 04:52
Hide Volumes / Extra Boot Entries, to remove them out of your boot screen add these in to your Clover Configurator by mounting your efi with your choice of app an opening your config.plist with Clover Configurator, in section GUI in the Hide Volume to the right side of the app
Windows
Preboot
Recovery
NO NAME
Make sure your scan settings are correct in the GUI section
select Custom, Entries, Tool
now on the config.plist open with TexEdit search for Scan there might be a "#" in front of Scan remove that so appears as so
<key>Scan</key>
<dict>
<key>Entries</key>
<true/>
<key>Legacy</key>
<false/>
<key>Linux</key>
<false/>
<key>Tool</key>
<true/>
:superman :superman :superman :superman :superman
:superman :superman
Sampath007
CPU: i7-8550u
Motherboard: Acer Nitro 515-31
GPU: UHD 620
Post by Sampath007 » 12 Nov 2018, 18:13
Good job
Post by MaLd0n » 12 Nov 2018, 18:29
:guitar
erroruser
Post by erroruser » 12 Nov 2018, 18:36
Sampath007, MaLd0n,
8-) Thank you guys 8-)
:superman :superman
Stavg
CPU: i3 6100
Motherboard: GA-H110M
GPU: RX 480
Post by Stavg » 05 Dec 2018, 20:25
Worked like a charm! thanks! :guitar
erroruser
Post by erroruser » 05 Dec 2018, 20:29
Stavg, :guitar :guitar
:superman :superman
aaresayphss
CPU: i7-7700HQ
Motherboard: MSi
GPU: Intel HD Graphic 630
Post by aaresayphss » 26 Feb 2019, 18:03
Hi !!!
I cant hide BBoot Windows from EFI. It's only show on CLOVER boot scren and I cant found it on macOS
My EFI Folder ( sorry for erternal link. I can't att file in here, it's say too large file. )
Thanks you for your had work.
erroruser
Post by erroruser » 26 Feb 2019, 18:15
aaresayphss, try this clover [External Link Removed for Guests]
:superman :superman
makmp
CPU: i7 7820x
Motherboard: rog strix X299
GPU: radeon RX 580
Post by makmp » 01 Apr 2019, 15:34
Hello Guys!! After recovering my system from back up i lost the option in clover to boot into recovery mode (option is missing) is there any chance to get this option back?
erroruser
Post by erroruser » 01 Apr 2019, 16:01
makmp, on the boot screen press F3 to show hidden entries
:superman :superman
makmp
CPU: i7 7820x
GPU: radeon RX 580
Post by makmp » 01 Apr 2019, 16:07
01 Apr 2019, 16:01
I did try that but no recovery partition. Not even preboot
erroruser
Post by erroruser » 01 Apr 2019, 18:41
makmp, you could always just use your usb to boot back on then reinstall clover boot loader an put your clover folder back that is stored in the main drive efi-backups as everytime the clover is updated it stores a copy
:superman :superman
makmp
CPU: i7 7820x
GPU: radeon RX 580
Post by makmp » 01 Apr 2019, 19:28
01 Apr 2019, 18:41
I boot mojave properly from my ssd so there is no need to boot from usb. I reinstalled clover boot loader and replaced clover from backup and after clover folder with the one that fits my chipset (X299). Recovery mode has disappeared from boot options. I see every other partition (boot windows from recovery etc) but not the mac recovery partition. Mac os is installed on its own drive
Montmac
Post by Montmac » 29 Jun 2019, 00:57
I'm showing 4 different partitions on my clover boot screen besides High Sierra and Mac Recovery. How do I find out the names of the other boot entries? I have win 10 on another disk and it's showing 4 entries. I only need one of those to boot windows. The other 3 don't do anything.
kxbarbosa
CPU: i5 9400f
Motherboard: Asus TUF h310m plus gaming
GPU: Sapphire RX 580 8gb
Post by kxbarbosa » 07 Sep 2019, 11:51
im trying to hide MSR partition (16mb) but with no success.
I tried in clover configuration hide volume section insert the volume uuid (E3C9E316-0B5C-4DB8-817D-F92DF00215AE) and disk uuid but didn't work!
Anybody can't suggest what I can do?
Shen
CPU: shit
Motherboard: shit
GPU: shit
Post by Shen » 08 Oct 2019, 15:02
same here :crazy: :crazy: :crazy: :crazy:
