iMessage Fixer
cyberdevs
Developer
Developer
CPU: Intel Core i7 6700K
Motherboard: Gigabyte Z170X-Gaming 5
GPU: AMD RX 580
iMessage Fixer
Post by cyberdevs » 08 Sep 2018, 17:25
Hello guys,
A while back I wrote a tiny app to fix certain issues with iMessage/Messages and FaceTime.
This app will remove corrupted files and the Messages/FaceTime database and the Network Interface preference files which might be the cause for iMessage/Messages and FaceTime not working properly.
If you are having activation issues with iMessage, this application is not the answer but if you already activated iMessage on your Mac or Hack and the Messages is acting up you can use this app to fix it.
iMessage Fixer.zip
There are other issues that can result in imessage/Messages and FaceTime not working properly like using a blacklisted Serial Number or MLB or SmUUID or simply an unactivated AppleID. If that's the case you need to use [External Link Removed for Guests] (or newer version) to rebuild your SMBIOS data with the most updated details like shown in the picture below:
All you have to do is to select the SMBIOS section and then form the SMBIOS selector choose the most compatible SMBIOS with your hardware:
Then you need to select the RtVariable section to generate the MLB based on your SMBIOS data and then just click the Generate button next to ROM to automatically generate the MLB and ROM ID based on your SMBIOS and then copy/paste the MLB from the newly generated info into the MLB box next to the ROM filed. Save your new config.plist
Once you did the steps above and save the config, close Clover Configurator and the run the iMessage Fixer app and then reboot the computer, once macOS is loaded, login into iMessage or Messages using your AppleID and hopefully you can activate your iMessage and FaceTime.
Important Note:
If you already signed in AppStore or iCloud using your current config.plist you might need to remove that device from iCloud in order to prevent the Account Lock Up by Apple because once you change the Serial Number, MLB and SmUUID Apple's server will lock your account in order to protect your data and you need to rest the your AppleID's password.
I hope you find this helpful.
Cheers :)
If you find my posts or apps useful please feel free to [External Link Removed for Guests]
onemanosx
iMessage Fixer
Post by onemanosx » 08 Sep 2018, 18:41
Ran the app and rebooted. Greeted with "Messages is updating.." notification.
Its taking quite a while..Well, I'll just wait it out and update again how it works out. :D
Intel i7-6700HQ, 8GB RAM (UEFI Clover Mojave)
MSI B360 Gaming Arctic
Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Mojave)
cyberdevs
Developer
Developer
GPU: AMD RX 580
iMessage Fixer
Post by cyberdevs » 08 Sep 2018, 19:01
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] Its taking quite a while..Well, I'll just wait it out and update again how it works out.
Just open Messages and login, you don't have to wait that long ;)
onemanosx
iMessage Fixer
Post by onemanosx » 08 Sep 2018, 19:13
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] you don't have to wait that long ;)
Well, I just did LOL
In any case, I am sure your app did what its supposed to. System asked me to relogin into icloud so I guess that settles it for that part. Still cant activate imessage. Must be some config I might hv missed.
Edit: Picture deleted due to privacy
cyberdevs
Developer
Developer
GPU: AMD RX 580
iMessage Fixer
Post by cyberdevs » 08 Sep 2018, 19:17
Have you ever used this Apple ID on any legitimate apple devices?
You need to scratch your Apple ID on the bottom of the window as well ;)
onemanosx
iMessage Fixer
Post by onemanosx » 08 Sep 2018, 19:28
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] scratch your Apple ID on the bottom of the window as well
LOL! Silly me!
Tried sending message doesnt work.
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] Have you ever used this Apple ID on any legitimate apple devices?
Yeap, on my iPhone
cyberdevs
Developer
Developer
GPU: AMD RX 580
iMessage Fixer
Post by cyberdevs » 08 Sep 2018, 19:37
Yeah my bad I didn't notice that the iMessage is still inactive!
Have you ever used this Apple ID on any legitimate apple devices like an iPhone, iPad or MacBook etc.?
This app won't activate the iMessage, if you get a prompt that "You cannot sign in to iMessage on this Mac at this time." error you need to contact Apple and send them the customer code and sadly there's no other way at least I haven't found one yet :(
Added in 17 minutes 50 seconds:
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]Yeap, on my iPhone
Take a look at this guide this might help:
I'm testing it right now to see if that method is working
kaitgaming
CPU: i3 8100
Motherboard: msi z370 kaitgaming
GPU: msi 1070ti gaming x 8gb
iMessage Fixer
Post by kaitgaming » 17 Nov 2018, 14:16
help me
meeraji4u
CPU: i5
Motherboard: Asus
GPU: gtx 1050 ti 4gb
Re: iMessage Fixer
Post by meeraji4u » 04 Feb 2019, 11:33
how to fix nvidia 1050ti graphics issue for mojave
Re: iMessage Fixer
Post by MaLd0n » 04 Feb 2019, 11:35
04 Feb 2019, 11:33
forget nvidia for mojave
use a correct forum section
-Donated? Send me one PM-
Wizzard
CPU: Intel m3-7Y30
Motherboard: Teclast F6 Pro
GPU: Intel HD 615
iMessage Fixer
Post by Wizzard » 15 Apr 2019, 21:00
Hi, I tried a lot of guides, including the mentioned but cannot login to imessage neither facetime. I have working icloud account activated on real iphone, but I see that I have linked the telephone number of that iPhone that is not mine and I cannot remove it without loging to iMessage, apparently.
Is there any log file where can I at least check what is wrong with iMessage?
dang0886919262
CPU: i5 4310u
Motherboard: dell
GPU: dell
iMessage Fixer
Post by dang0886919262 » 15 May 2019, 17:12
thank's you !
i want to file olivia
cyberdevs
Developer
Developer
GPU: AMD RX 580
iMessage Fixer
Post by cyberdevs » 15 May 2019, 17:25
15 Apr 2019, 21:00
Sadly there is no log to check for the error you are getting.
15 May 2019, 17:12
thank's you !
You're welcome but I don't know what do you mean exactly :)
rankawarj
CPU: intel-i7700HQ
Motherboard: MSI-GL62-7QF
GPU: Nvidia-GTX-960M
iMessage Fixer
Post by rankawarj » 24 Jun 2019, 04:58
not working for me
Return to “Apps”
