ESP Mounter Pro v1.9
Mirone
CPU: Intel Core i7-8700k
GPU: Radeon RX 560 - 4GB
Post by Mirone » 01 Jul 2018, 17:09
About This File:
ESP Mounter Pro is a new top bar application to manage your EFI System Partition(s). You can mount or umount any ESP you have on any disk you have directly from its popover window.
This app use advanced APIs to perform all operations and no AppleScript or scripts are used: only code!
Require 10.9 +, works good in Mojave Beta!!
// Created by Micky1979 on 15/06/16.
// Copyright © 2016 Micky1979 All rights reserved.
app icon by Mirone (thanks)
Does not show an EFI Partition if your disk is not GPT (or if smaller than 1GB). Cannot mount it if corrupted!.
Thank you [External Link Removed for Guests] for keeping up his great work!
New Version ESP Mounter Pro v1.9.1
Micky1979
Developer
Developer
Post by Micky1979 » 01 Jul 2018, 17:13
01 Jul 2018, 17:09
Thanks to you!
Post by MaLd0n » 01 Jul 2018, 17:50
Very Nice! Thanks for update, guys!!!
-Donated? Send me one PM-
dedicahyadi
CPU: Intel Core i5 7200U
Motherboard: Asus A456URK
GPU: Intel(R) HD Graphics 620
Post by dedicahyadi » 02 Jul 2018, 00:12
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] About This File:
Thank you Micky1979 for keeping up his great work!
Download Here
amazing, thanks for creator.
matgen84
CPU: i7 9700K
Motherboard: Asus Prime Z390-A
GPU: Radeon RX 580 Armor
Post by matgen84 » 02 Jul 2018, 04:50
Thanks for update :D
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 02 Jul 2018, 16:59
thanks both
daliansky
CPU: i7-7500u
Motherboard: 07T996
GPU: HD620
Post by daliansky » 19 Jul 2018, 02:29
good job
johnnywolinger
CPU: Intel® Core™ i5-7200U 2.5GHz
Motherboard: Acer F5-573G-50KS (Ironman SK)
GPU: NVIDIA® 940MX 2GB DDR4
Post by johnnywolinger » 19 Jul 2018, 13:05
Nice tool, thanks bro :D
JorgeMax
CPU: INTEL Core i5-3470
Motherboard: Gigabyte GA-Z77P-D3
GPU: Gigabyte Radeon HD7850
Post by JorgeMax » 26 Jul 2018, 19:38
Thanks Mirone
And a thank you to Micky1979
Placa-mãe: Gigabyte GA-Z77P-D3 (rev1.1, Bios F8e)
Processador Intel: Core i5 3470
Placa de vídeo Gigabyte: Radeon HD7850
Memória kingston 16G DDR3
Wi-Fi/BT4.0 Broadcom: BCM94360CD
Rede Realtek: RTL8111E-VL/8168E-VL
Codec Áudio Realtek: ALC887
onemanosx
Post by onemanosx » 28 Jul 2018, 08:00
Hi!
First off I would like to thank you for the amazing useful tool!
However, I am having a small issue with it not able to open the mounted partition. See attached video example. I have 2 drives both in GPT. While my hdd is able to mount and open folder, my ssd (No Name) can only be mounted but not opened through the app.
Do you think I can manage this by just renaming "No Name" to "EFI"?
Thank you!
Intel i7-6700HQ, 8GB RAM (UEFI Clover Mojave)
MSI B360 Gaming Arctic
Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Mojave)
Allan
CPU: i5-3210M
Motherboard: InsydeH20
GPU: IntelHD 4000
Post by Allan » 28 Jul 2018, 15:39
I have this same issue if I use APFS. In HFS+ I have no problems.
onemanosx
Post by onemanosx » 29 Jul 2018, 04:05
Strange. I am using HFS+tho..
Micky1979
Developer
Developer
Post by Micky1979 » 04 Aug 2018, 12:43
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] Do you think I can manage this by just renaming "No Name" to "EFI"?
Nope ESP Mount Pro doesn't rely on the name.
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] However, I am having a small issue with it not able to open the mounted partition. See attached video example. I have 2 drives both in GPT. While my hdd is able to mount and open folder, my ssd (No Name) can only be mounted but not opened through the app.
Thanks for the video, so I think I solved the problem, try attached. Be aware that a new helper tool will be installed and the first time will require the app to be manually restarted. Let me know.
EDIT
App repacked with a new certificate. This one will be valid for the next 10 years. :D
onemanosx
Post by onemanosx » 04 Aug 2018, 13:30
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] Thanks for the video, so I think I solved the problem, try attached. Be aware that a new helper tool will be installed and the first time will require the app to be manually restarted. Let me know.
Yes! This works! Glad the video helps! Thank you!!
Jenny David
Developer
Developer
CPU: i5 - 3360M
Motherboard: Intel HM76 (7 Series)
GPU: Intel HD 4000
Post by Jenny David » 04 Aug 2018, 16:42
Just tested v1.9.1. Working perfectly. Thank you so much @Mirone & @Micky1979 :)
Mirone
Post by Mirone » 04 Aug 2018, 20:13
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] App repacked with a new certificate. This one will be valid for the next 10 years.
:o
draque
CPU: 8700K
Motherboard: N7 z370
GPU: Zotac Geforce 1080Ti Amped Ex
Post by draque » 14 Aug 2018, 03:17
Beautiful work @Mirone & @Micky1979!
Just a note, I set up one of my monitors for HiDPI and it makes the app's icon distort in the menu bar. I've attached a picture. Any fixes for that?
sjkobgy
Post by sjkobgy » 11 Sep 2018, 22:36
appriciate you. Thanks for update.
msbc
CPU: i7-8700K
Motherboard: ASUS MAXIMUS X HERO
GPU: AMD RX580
Post by msbc » 12 Sep 2018, 01:46
Hi,
ESP displays the disk name as "Untitled 2" for my boot disk - should be "Sierra".
AaMir
CPU: Intel i7-6500U
Motherboard: HP Notebook 15
GPU: Intel HD 520
Post by AaMir » 26 Sep 2018, 11:09
nice work.....keep it up...Thank u
Return to “Apps”
