Asus Rampage Formula - Sound Driver
zimdamn
CPU: Intel Quad Core Xeon 2,84 GHz
Motherboard: Asus Rampage Formula
GPU: ATI Radeon HD 4870 X2
Post by zimdamn »
Hello,
I have installed iAtkos L2 on my computer, everything work well except the sound. I have an [External Link Removed for Guests] (chipset X48).
Do you have any idea about the process to follow to enable it ?
Thanks in advance for your replies.
Mirone
Developer
Developer
CPU: Intel Core i7-8700k
GPU: Radeon RX 560 - 4GB
Re: Asus Rampage Formula - Sound Driver
Post by Mirone »
zimdamn wrote:Hello,
try this: [External Link Removed for Guests]
zimdamn
Post by zimdamn »
Thank you but it still do not work...
Mirone
Developer
Developer
Post by Mirone »
Mirone wrote: try this: [External Link Removed for Guests]
you edited your dsdt for the kext to work?
zimdamn
Post by zimdamn »
Mirone wrote: you edited your dsdt for the kext to work?
No, I only copied/pasted the AppleHDA.kext in /System/Library/Extensions/ and I don't know if it is the right thing to do.
Mirone
Developer
Developer
Post by Mirone »
You need to edit your dsdt.
send me and I edit it for you
zimdamn
Post by zimdamn »
Please find attached my dsdt extracted from windows.
Thank you for your help.
Mirone
Developer
Developer
Post by Mirone »
zimdamn wrote:Please find attached my dsdt extracted from windows.
Try this:
zimdamn
Post by zimdamn »
I have installed the dsdt on my Extra directory and reboot but the sound is not working.
Mirone
Developer
Developer
Post by Mirone »
zimdamn wrote:I have installed the dsdt on my Extra directory and reboot but the sound is not working.
use this [External Link Removed for Guests]
zimdamn
Post by zimdamn »
Mirone wrote: use this [External Link Removed for Guests]
Ok, I have installed VoodooHDA-v2.7.4.r63 and now I have Voodoo in my parameters but the only output displayed is Digital-out (HDMI).
When I boot my Hackintosh, I have a sizzle so I assume that it is almost good.
I have also tried to insert my device ID but I don't know how to rebuild the kernelcache.
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt »
terminal
sudo kextcache -prelinked-kernel
or
[External Link Removed for Guests] - join me at irc.freenode.net/##Olarila
zimdamn
Post by zimdamn »
artur-pt wrote:hello
terminal
or
Hello,
I have this message in the terminal when I do this:
Can't read info dictionary for VoodooHDA.kext: IOCFUnserialize: syntax error near line 35.
/System/Library/Extensions/System.kext/PlugIns/Libkern6.0.kext doesn't support architecture x86_64; omitting from prelinked kernel.
My Info.plist is attached.
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt »
something wrong with the kext voodoohda
the other msg is normal no problem
try another voodoohda
zimdamn
Post by zimdamn »
Hello,
I have tried several voodoo and nothing worked.
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt »
is that u sound ?
ADI 1988B 8 -Channel High Definition Audio CODEC
try the last one
or
Return to “Lion (10.7)”
