Nao estou conseguindo abrir alguns aplicativos
ramonmariano
CPU: I7 3770
Motherboard: ASUS H61
GPU: gtx 1070
Post by ramonmariano » 06 Sep 2019, 11:19
de ontem pra hoje alguns aplicativos pararam de funcionar... poderiam me ajudar, vou anexar os erros... muito grato desde já!
Process: RightFont 5 [1080]
Path: /Applications/RightFont 5.app/Contents/MacOS/RightFont 5
Identifier: com.rightfontapp.RightFont5
Version: 5.5.4 (2651)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: RightFont 5 [1080]
User ID: 501
Date/Time: 2019-09-06 08:16:03.846 -0300
OS Version: Mac OS X 10.13.6 (17G2208)
Report Version: 12
Anonymous UUID: 34C96CA0-0676-ABA8-94B1-1BC990912DC6
Time Awake Since Boot: 220 seconds
System Integrity Protection: disabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x5] Code Signature
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/Sparkle.framework/Versions/A/Sparkle
Referenced from: /Applications/RightFont 5.app/Contents/MacOS/RightFont 5
Reason: no suitable image found. Did find:
/Applications/RightFont 5.app/Contents/MacOS/../Frameworks/Sparkle.framework/Versions/A/Sparkle: code signature invalid for '/Applications/RightFont 5.app/Contents/MacOS/../Frameworks/Sparkle.framework/Versions/A/Sparkle'
/Applications/RightFont 5.app/Contents/MacOS/../Frameworks/Sparkle.framework/Versions/A/Sparkle: stat() failed with errno=1
Binary Images:
0x10d854000 - 0x10da68fff +com.rightfontapp.RightFont5 (5.5.4 - 2651) <E224218E-EE71-3637-B2FB-A74E9A24EDF6> /Applications/RightFont 5.app/Contents/MacOS/RightFont 5
0x10db1c000 - 0x10db3dff7 +org.cocoapods.AFNetworking (3.2.1 - 1) <8F525D7C-FC3D-38E8-A9AF-1F730CAFA2DC> /Applications/RightFont 5.app/Contents/Frameworks/AFNetworking.framework/Versions/A/AFNetworking
0x10db7d000 - 0x10db9eff7 +org.cocoapods.CocoaLumberjack (3.4.2 - 1) <E85D49D9-E6FD-3B53-9F02-51B75313B4D0> /Applications/RightFont 5.app/Contents/Frameworks/CocoaLumberjack.framework/Versions/A/CocoaLumberjack
0x10dbcf000 - 0x10dbd9fff +org.cocoapods.RNCryptor-objc (3.0.6 - 1) <2F8FA100-1091-3390-A814-B7F4E2B9E104> /Applications/RightFont 5.app/Contents/Frameworks/RNCryptor_objc.framework/Versions/A/RNCryptor_objc
0x11099a000 - 0x1109e4acf dyld (551.4) <8A72DE9C-A136-3506-AA02-4BA2B82DCAF3> /usr/lib/dyld
0x7fff2c292000 - 0x7fff2d0f0fff com.apple.AppKit (6.9 - 1561.60.100) <03EC3B7A-1F79-3120-88FA-89187C073964> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2d142000 - 0x7fff2d142fff com.apple.ApplicationServices (48 - 50) <AFFBD94A-AF76-336E-B53E-57524EAE8EF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff2fe51000 - 0x7fff2fe51fff com.apple.CoreServices (822.36 - 822.36) <C8368F17-1589-3BA5-A0E7-89CB8DF2454F> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff30e39000 - 0x7fff311fffff com.apple.Foundation (6.9 - 1454.90) <8EA924F3-ADAE-3F4B-8482-8B11C027D9A5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff3ab43000 - 0x7fff3ae6efff com.apple.security (7.0 - 58286.70.7) <BD7DBC67-3301-3D64-9915-9B0151E1A7CA> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff54c5b000 - 0x7fff54cb1fff libc++.1.dylib (400.9) <7D3DACCC-3804-393C-ABC1-1A580FD00CB6> /usr/lib/libc++.1.dylib
0x7fff5660a000 - 0x7fff56797ff7 libsqlite3.dylib (274.8.1) <B70A2908-E0F7-364E-952A-1D2D19787B89> /usr/lib/libsqlite3.dylib
0x7fff56af2000 - 0x7fff56b04ffb libz.1.dylib (70) <48C67CFC-940D-3857-8DAD-857774605352> /usr/lib/libz.1.dylib
Model: iMac13,2, BootROM 285.0.0.0.0, 4 processors, Intel Core i7, 3,39 GHz, 16 GB, SMC 2.11f16
Graphics: NVIDIA GeForce GTX 1070, NVIDIA GeForce GTX 1070, PCIe
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, Kingston, 9905471-069.A00LF
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, Kingston, 9905471-069.A00LF
Bluetooth: Version 6.0.7f11, 3 services, 26 devices, 1 incoming serial ports
Network Service: USB 10/100/1000 LAN, Ethernet, en3
Serial ATA Device: ST1000DM010-2EP102, 1 TB
Serial ATA Device: KINGSTON SUV400S37/240GB, 240,06 GB
Serial ATA Device: ST4000DM005-2DP166, 4 TB
Serial ATA Device: KINGSTON SV300S37A120G, 120,03 GB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: Magic Trackpad 2
USB Device: CSR8510 A10
USB Device: Hub
USB Device: USB 10/100/1000 LAN
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: Gaming Mouse G402
Thunderbolt Bus:
Post by MaLd0n » 06 Sep 2019, 14:26
ramonmariano, tem de ver sobre esse RightFont 5, veja se tem um update
ramonmariano
CPU: I7 3770
GPU: gtx 1070
Post by ramonmariano » 08 Sep 2019, 08:34
06 Sep 2019, 14:26
Mano era isso mesmo, tive que apagar e reinstalar, varios aplicativos ficaram com o mesmo problema, aparentemente foi quando eu executei um script pra abrir o gatekeeper.... ou um app pra deixar a janela fixada no top...um dos dois... ai bugou geral, mas ja esta normal, de toda forma muito grato pela forca!
Post by MaLd0n » 08 Sep 2019, 15:45
ramonmariano, ;)
