[HELP] SABERTOOTH P67 + RX 280 WON'T BOOT TO INSTALLER
guidelamuta
CPU: i7 7700k
Motherboard: z270x gaming 7
GPU: 1080 ti
Post by guidelamuta » 10 Jul 2019, 13:41
I tried all bios and EFI configurations that I found, always get the Forbidden Symbol.
Any ideias?
[Tried Mojave and High Sierra]
Thx
Post by MaLd0n » 10 Jul 2019, 14:09
guidelamuta, ahci enable?
guidelamuta
CPU: i7 7700k
GPU: 1080 ti
Post by guidelamuta » 10 Jul 2019, 15:11
Yes MaLd0n,
SATA Mode Selection - AHCI
S.M.A.R.T Status Check - Enabled
Post by MaLd0n » 10 Jul 2019, 15:14
guidelamuta, use usb 2 port
guidelamuta
CPU: i7 7700k
GPU: 1080 ti
Post by guidelamuta » 10 Jul 2019, 15:28
I will try tonight.
Thank you very much.
guidelamuta
CPU: i7 7700k
GPU: 1080 ti
Post by guidelamuta » 10 Jul 2019, 22:32
Hi again MaLd0n,
I tried the USB 2.0 ports and got black screen instead the forbidden one.
Then I did disable all this options (everythink was Enable, except Marvel):
I don't know what options worked out, but I manage to boot the Mojave image.
But then I got this message:
There is any way to bypass this?
Sorry for all the trouble.
Added in 13 minutes 20 seconds:
I changed to iMac 18,2 and WORKED!
Muito obrigado pela ajuda!
:frantics
Post by MaLd0n » 11 Jul 2019, 01:14
guidelamuta, use smbios iMac13,2, work too
guidelamuta
CPU: i7 7700k
GPU: 1080 ti
Post by guidelamuta » 12 Jul 2019, 22:55
Hi MaLd0n, me again.
I manage to install everything, smbios 13,2, but...
When I installed clover via UEFI, Clover won't show up.
When I installed clover via Legacy, Clover boots, but when all the steps finish and should get to the system I get a black screen.
When boot with the Olarila Mojave Pen Drive, the system works fine.
Any tips?
:bye
Post by MaLd0n » 13 Jul 2019, 00:45
guidelamuta, copy efi folder fom olarila usb stick to ur hdd/ssd :mrgreen:
guidelamuta
CPU: i7 7700k
GPU: 1080 ti
Post by guidelamuta » 13 Jul 2019, 01:47
Didn't work, but in reverse, I used your EFI folder for sandybridge in the PENDRIVE clover folder, and the system is perfect.
I don't know what is causing this, but one possible solution is leave a slave pendrive forever booting the system.
:help
Return to “Hardware”
