mid price Hackintosh i5 9600
fickerr
CPU: Intel i7 5500U
Motherboard: Asus Zenbook UX 303L
GPU: Intel HD5500
Post by fickerr » 10 Jun 2019, 19:11
Hi,
I wanna build me a mid price hackintosh with an intel i5 9600.
What ATX mainboard would you recommend?
it should have USB 3.1 and Thunderbolt option for future usage.
And onboard graphics cause I don't need/want a dedicaded card for that PC.
Is GIGABYTE Z390 GAMING X working?
Post by MaLd0n » 10 Jun 2019, 19:36
fickerr, all gigabyte mobos working good
u can buy one h310 or z390, same result with more sata, usb ports
fickerr
CPU: Intel i7 5500U
GPU: Intel HD5500
Post by fickerr » 10 Jun 2019, 20:29
and what about ASUS PRIME Z370-A GAMING ATX Mainboard 1151 DP/HDMI/DVI/M.2/USB3.1
it has more display outputs
is it also compatible with i5 9600 and hackintosh?
Post by MaLd0n » 10 Jun 2019, 20:40
fickerr, work good too
fickerr
CPU: Intel i7 5500U
GPU: Intel HD5500
Post by fickerr » 10 Jun 2019, 21:36
awesome, thanks
fickerr
CPU: Intel i7 5500U
GPU: Intel HD5500
Post by fickerr » 20 Jun 2019, 18:53
Can you help me?
I have this setup now:
Mainboard: Asus Prime Z370-A
CPU: Intel Core I5 9600k
GPU: Internal Intel UHD 630
Installed with the 10.14.5 Olarila image without problems, downloaded the "--CHIPSET SERIES 10, 20 and 30 (SKYLAKE / KABYLAKE / COFFEELAKE)" and replaced the efi/clover folder with it. Installed clover again.
Booting without errors but I have some graphic glitches. Windows are flickering strangely.
In this guide [Local Link Removed for Guests] some of the clover install options doesn't exist in the newest clover installer from sourceforge.
Guide:
Newest Clover:
Attached the sendme.zip vom the Run.me app.
Do you know how to fix the graphic glitches?
Best regards and thanks in advance
Post by MaLd0n » 21 Jun 2019, 03:39
fickerr,
use imac18,1 smbios
Return to “Desktop”
