"Mac OS cannot be installed on this computer" Issue
syncopated84
CPU: i5 9600K
Motherboard: Gigabyte Z390 UD
GPU: Sapphire Pulse RX580 8GB
Post by syncopated84 »
Trying to install Mojave with the new 10.4.4 image using etcher on windows 10.
Booted into install after an issue of unplugging and replugging in my HDMI to get some display after verbose. (annoying, but whatever)
Tried to install but get this message every time after 2 minutes into the process. Tried to erase and re-partition as APFS/GUI partition table, by the 3rd time diskutil always errors and I cant even erase the drive.
So I tried to reinstall on my old high sierra drive (that I haven't used in over a year because I gave up on troubleshooting recent hackintosh/mac alltogether.....but here I am again), and same issue. Going to erase the drive and try again, but I have a feeling it'll do the same thing.
i5 9600K cpu on a gigabyte z390 UD mobo
Sapphire RX 580
PNY 240gb ssd ...... and another 960gb ssd (forgot who makes it, does it really matter?)
Please help. Do I need to add/delete some stuff that comes with the Olarila image? What are possible reasons this is happening?
:wallbash
Post by MaLd0n »
syncopated84, follow step by step here
syncopated84
CPU: i5 9600K
Fixed it. I did several things but I'm thinking it was because of using etcher on the windows side. I used win32diskimager instead and did the trick.
I am now booted into an installed Mojave. Now to install clover and do the fine tuning.
Disregard this post, unless it helps you.
Post by MaLd0n »
syncopated84, ;)
theboleslaw
CPU: i7-950
Motherboard: DX58SO
GPU: RX 570
Post by theboleslaw »
Me too I followed the Guide, hmmm is it need to install first 10.14 cause I tried installing the latest immediately and after language selection it says cannot be installed on this computer.
Post by MaLd0n »
theboleslaw, x58 chipset? u need use a supported smbios
theboleslaw
CPU: i7-950
Motherboard: DX58SO
GPU: RX 570
Yes I already downloaded the config from here with x58
my Specs:
Motherboard: Intel DX58SO
CPU: i7-950
RAM: 8GB 1333mhz Triple Channel
Post by MaLd0n »
theboleslaw, use a iMac13,2+ smbios, MacPro6,1 work too in ur case
theboleslaw
CPU: i7-950
Motherboard: DX58SO
GPU: RX 570
19 May 2019, 00:17
Got it I just manage to load High Sierra instead of Mojave now another problem is the install keeps failing maybe hard drive issue. hmmm
Post by MaLd0n »
theboleslaw, need a ICH10 AHCI fix
theboleslaw
CPU: i7-950
Motherboard: DX58SO
GPU: RX 570
Thanks ! Will try it later maybe this is the issue all the time.
theboleslaw
CPU: i7-950
Motherboard: DX58SO
GPU: RX 570
19 May 2019, 15:01
How to use it? I don't have access to any mac.
robertorcs
CPU: Intel Core i3-350M
Motherboard: Hewlett-Packard 1435
GPU: Intel HD Graphics-IronLake
Post by robertorcs »
Boa tarde, tenho uma DX58SO e não estou conseguindo de jeito nenhum chegar na tela de Instalação, alguém saberia certinho o que mudar na BIOS?????
Post by MaLd0n »
robertorcs, posta uma foto do erro
Return to “Mojave (10.14)”
