🎉 NEW Discord server!
Question about Catalina
artin
CPU: 6700hq
Motherboard: asus
GPU: gtx 960m , hd530
Post by artin »
hi dear maldon
it's safe to install ? (stable?)
i have asus zenbook pro ux501 vw
i7 6700hq(h170) 12gb ram gtx960m(gm107) intel hd 530
4k touch display
and i have install mojave 10.14.4 with your dsdt and clover 100/200/300 folder
i can use my config.plist and dsdt with new clover folder?
and can you upload catlina Olarila.raw to google drive or others ? torrent my country are bad to access tnx a lot
please answer
best regard
Catalina Olarila
Post by MaLd0n »
artin, no, wait next releases
artin
CPU: 6700hq
Motherboard: asus
Post by artin »
04 Jun 2019, 15:19
ok tnx
limpid
Donator
Donator
CPU: i7-6800K
Motherboard: MSI X99A gaming 7
GPU: GTX 1080 Founder ed.
Post by limpid »
pls help
i install catalina now with your 200 series folder EFI
now ALL work 10 sek and ecran glitch and duble pictures and freze.
what is vrong.
system is
GA Z270m D3H .i5-7600k/ With Onbord Graphics IGPU
Post by MaLd0n »
limpid, use hackintool for create a video patch
limpid
Donator
Donator
CPU: i7-6800K
Post by limpid »
I tried but did nothing .on mojave q10.14.5 is same I can not help myself
only 10.14.4 work for my but after update i only try
Post by MaLd0n »
limpid, 10.14.5 have a several updates for ur hardware
limpid
Donator
Donator
CPU: i7-6800K
Post by limpid »
Post by MaLd0n »
limpid, ;) :mrgreen:
limpid
Donator
Donator
CPU: i7-6800K
Post by limpid »
close buton is blue heh
momo963
CPU: Intel i7 4770K
Motherboard: GIGABYTE Z87X-UD3H
GPU: HD 4600
Post by momo963 »
Hello MaLd0n,
I'm missing Install Anyway button in Clover post installation.
I have the same hardware configuration and follow the same install procedure when I'm installing Mojave or Catalina Beta1 as you can see on images bellow there is Install Anyway button.
Catalina Beta1
But in Catalina Beta 2 I'm missing Install Anyway button.
Do you have any idea what I can try to fix it, please?
Post by MaLd0n »
momo963, u dont need install clover, just copy ur full efi folder
momo963
CPU: Intel i7 4770K
GPU: HD 4600
Post by momo963 »
Hello MaLd0n, I’m not sure if I follow you but I’m doing step number 7 from installation guide.
7- Install Clover Bootloader in SSD
Post by MaLd0n »
momo963, yes, but u can ignore this step if u have a full efi folder
momo963
CPU: Intel i7 4770K
GPU: HD 4600
Post by momo963 »
MaLd0n, thank you for your advice. It works.
vrondena
CPU: i7
Motherboard: Dell xps13 9343
GPU: hd5500
Post by vrondena »
there are possibilities for catalina image with hfs+ ?
dell xps13 9343
core i7
Intel HD5500
-ram 8 gb ddr3
-hard disk da 256 gb SDD
Post by MaLd0n »
vrondena, [External Link Removed for Guests]
Onay Rodriguez
CPU: Intel Core i9 9900K
Motherboard: Asus ROG Maximus Hero XI Z390
GPU: AMD Radeon Vega 56
Post by Onay Rodriguez »
Hey guys, I’ve been searching the Internet for almost three hours, trying to find the solution to my problem and I’ve been unsuccessful.
I’ve successfully installed macOs Catalina Beta 4 on my computer via USB installer with clover r5018. The problem begins when I try to install Clover in my hard disk for booting without the USB. Catalina says that Clover installer is not compatible with the the OS because is trying to install on the System Partition.
The installer gives me the option to “install anyway” and I select it. The installation of Clover on my Hard Disk finishes and I put in the installation folder all the kexts and config files, but when I try to boot the PC, it doesn’t boot at all from that clover installation, it’s like if Catalina is preventing Clover to mark the Efi partition as bootable. My board’s boot menu doesn’t see that Efi partition as bootable.
I already tried to mount Catalina System Partition as writable with Hackingtool (thanks to that I was able to add fixes to my monitor) and then repeat the process of installing clover with System Partition mounted as writable, but the clover installation package gives the same error (Not compatible with Catalina ‘cause is trying to install on System Partition) and after installation, the boot menu of my computer doesn’t recognise that Efi partition as bootable.
Does anyone has had this problem?
What can I do to successfully install Clover on my hard disk in Catalina?
Thanks in advance
Post by MaLd0n »
Onay Rodriguez, u don't need install Clover, just put ur full EFI folder into EFI partition and reboot
Onay Rodriguez
24 Jul 2019, 18:52
Ok, thanks for the quick response. Yep! It worked. Thank you very much 🙏.
Return to “Catalina (10.15)”
