MacOs Catalina Hackintosh
erroruser
CPU: AMD Ryzen 7 3700X
GPU: Sapphire rx 5700 XT
Post by erroruser »
metalzone, add this since your using beta "-brcmfxbeta"
for boot args then try
:superman :superman
metalzone
CPU: i3-8100
Motherboard: Gigabyte B360m DS3H
GPU: Onboard HD 630
Post by metalzone »
10 Jun 2019, 19:30
no way... kernel panic
erroruser
Post by erroruser »
try this also -lilubeta
Added in 5 minutes 11 seconds:
on my laptop with clover i am using these so try them out an these are the boot args i am using with no issues dart=0 debug=0x100 -no_compat_check -v
Archive.zip
:superman :superman
czerwus
CPU: i5 4690k
Motherboard: Asrock Z97 PRO4
GPU: Asus Radeon R9 380X Strix
Post by czerwus »
Hi guys.
I tried to work with hackintosh years ago using iATKOS images. Since then i upgraded my configuration and I ma running on Intel i5 4690K, Asrock Z97 pro4 motherboard and Radeon R9 380. Is there any chance to run this distro on my configuration? Is there any step by step book for begginers? I trying to search answers to my questions by my own but i dont know... it seems that instalation of hackintosh thisdays is much much harder and more complicated than it was 10 years ago when i tried to do this. I'll be gratfull for any advice.
Gretings form Poland :) And please excuse me my poor english :)
Post by MaLd0n »
czerwus, [Local Link Removed for Guests]
santes
CPU: I5 7600K
Motherboard: GA-Z270-HD3P
GPU: Intel 630
Post by santes »
i'm facing some issue...plz help me out
their is a pink colour overly in entire screen.... when this problem occurred in mojave i simply fix with "whatever green kext " , i did the same in Catalina but its aint work... plz help me out what i supposed to do next
Post by MaLd0n »
santes, [Local Link Removed for Guests]
thetwoangels
CPU: AIO MEDION AKOYA
Motherboard: MITAC PH11LI - i5-4460S
GPU: HD4600
Post by thetwoangels »
It will be a matter of waiting for a next update to see if the problem persists or solves
metalzone
CPU: i3-8100
GPU: Onboard HD 630
Post by metalzone »
10 Jun 2019, 19:58
Archive.zip
thank`s, i removed all fakepciid from clover and user this 4 kext and all is OK! wifi and bluetooth! :crazy: :crazy:
Added in 2 minutes 23 seconds:
11 Jun 2019, 12:30
I also have kernel panic with this Ket
It will be a matter of waiting for a new update to see whether the problem is solved or persisted
use erroruser solution! remove all fakepiid from clover and paste this 4 kext in the other forlder! :guitar
erroruser
Post by erroruser »
metalzone, :guitar :guitar :guitar :guitar
:superman :superman
thetwoangels
GPU: HD4600
10 Jun 2019, 19:15
I used, but i have kernel panic with this!
It also gives me kernel panic with this kext
douglasdreer
CPU: i5 3rd
Motherboard: DELL Inpirion 14R 5420
GPU: HD 4000 / GF 630m
Post by douglasdreer »
@MaLd0n como está a estabilidade do sistema? Eu ouvi um boato que o iMessenger e o FaceTime voltou a funcionar com esta nova versão, está sabendo de algo?
______________________________________________
MacOS: Catalina
Notebook Dell Inspirion 14R 5420
Intel i5 3rd
Intel Graphics HD 4000
GeForce GT 630m (Disabled)
AR9485
Post by MaLd0n »
douglasdreer, muitos bugs, tem dde aguardar o próximo beta, deve sair hj ou amanhã
douglasdreer
CPU: i5 3rd
13 Jun 2019, 12:20
Ou melhor esperar o público ? Estou mandando o RunMe naquele outro tópico, ao dar o WakeUP ele não exibe mais o vídeo (HD Graphics 4000).
MacOS: Catalina
Intel i5 3rd
AR9485
mixha_m
CPU: Intel Core i5
Motherboard: HP
GPU: Intel HD 620
Post by mixha_m »
07 Jun 2019, 11:57
mixha_m, kernel to patch
9E 00 00 74 0E 8B -> 9E 00 00 EB 22 8B
by PMheart
Thank's MaLd0n, great work
Post by MaLd0n »
new beta
Roamaz
CPU: Intel core i5200-u
Motherboard: laptop
GPU: Intel hd5500 Gforce 830m
Post by Roamaz »
Hi, i want install Olarila Catalina on this laptop:
LAPTOP HP ENVY 17.3" -K206nl- 12GB Ram Intel Core i5-5200U with Intel HD Graphics 5500 (2.2 GHz, 3 MB cache, 2 cores) NVIDIA GeForce 840M (2 GB DDR3 dedicated)
But whe in insta menu, all system freeze and dont begin.
Whats the problem?.
Sorry for english, my natal language is Spanish.
Thank you, gracias, obrigado.
LAPTOP HP ENVY 17.3" - K206nl - 12GB Ram Intel Core i5-5200U with Intel HD Graphics 5500 (2.2 GHz, 3 MB cache, 2 cores) NVIDIA GeForce 840M (2 GB DDR3 dedicated)
Post by MaLd0n »
Roamaz, is a beta with some bugs
Aloisio
CPU: i73820
Motherboard: Asus P9X79 Pro
GPU: Radeon Asus RX580 8gb
Post by Aloisio »
Ola MaLdOn, estou com o problema igual ao do dengekiko. Sempre consegui fazer as instalações sem muitos problemas mais o Mojave e o Catalina Beta não está dando boot com sucesso. Uma vez que sempre usei as Graphics Cards Nvidia e quando deixaram de fazer os drivers resolvi usar a RX580 8gb e tenho tido o erro de Black Sreen também mesmo usando lilu e WhateveGree, quando tento o boot no Mojave que havia sido instalado em cima de uma GTX560 2gb. O que pode ser feito? Por gentileza.
Post by MaLd0n »
Aloisio, desativa csm
Return to “Catalina (10.15)”
