🎉 NEW Discord server!
MacOs Catalina Hackintosh
lubeats
CPU: Core i 7 4800MQ
Motherboard: QM87
GPU: Nvidia Quadro K610M
Post by lubeats »
@MalD0n that is my new DSDT patched by You?
OSI to XOSI then is not necessary, and the rest of patches in ACPI sections is OK?
Tell me with this changes, Could I install macOS without recovery mode?
In others words, I'll can install whithout problems?
About the sound You´re include the sound patch to Conexant CX20752? Because I'm using the AppleHDA Patcher tool to do it.
About my blink glitches in boot check on it this video
Thanks.
abenamu
CPU: i7-8700K
Motherboard: Asus Z370-E Gaming
GPU: AMD RX-590
Post by abenamu »
Hi,
NOt sure if I should ask on here the problem I have with Music, TV and Podcasts not loading my apple ID. Music does not load my NAS iTunes folder. Anybody else with this problem?
Thanks.
Post by MaLd0n »
abenamu, generate new smbios with last clover configurator version
abenamu
CPU: i7-8700K
GPU: AMD RX-590
Post by abenamu »
Ok, how do I generate a new SMBIOS on Clover Configurator? I have never done it, thanks.
Post by MaLd0n »
abenamu, just open app and generate in smbios tab
abenamu
CPU: i7-8700K
GPU: AMD RX-590
Post by abenamu »
I did that, one interesting and annoying thing in SMBIOS, the serial number SMBIOS generates does not change on About my mac.
the config.plist edited on clover configurator is not showing up the changes on serial number, model on about my mac.. How is that possible?
Post by MaLd0n »
abenamu, No idea
Tazorro
CPU: I3 2130
Motherboard: P8H61-M LE/USB3
GPU: GT 8800
Post by Tazorro »
Hi MaLd0n, I installed Mojave perfectly worked with formatting in apfs, as I already had the intention to upgrade to Catalina. At the end of the download when I select the disk it says that it is not possible to install on this system. Tips?
My config: Asus P6X58D-E, I7 930, 16Gb DDR3, RX 570 4GB
Post by MaLd0n »
Tazorro, use one supported smbios
Tazorro
CPU: I3 2130
GPU: GT 8800
Post by Tazorro »
12 Nov 2019, 18:44
Can you recommend a supported one?
Post by MaLd0n »
Tazorro, the best is used iMacPro1,1 for good hardware accel via dgpu
Tazorro
CPU: I3 2130
GPU: GT 8800
Post by Tazorro »
13 Nov 2019, 13:03
I did the update but at the end of the installation I always have a black screen.
I tried with both 14.2 and 1.1 but nothing.
Post by MaLd0n »
Tazorro, agdpmod=pikera
H4444
CPU: Sapphire Nitro+ RX 580
Motherboard: Gigabyte Z390 Designare
GPU: I9 9900K
Post by H4444 »
15 Oct 2019, 13:41
Hey, what's up, I have Olarilla Mojave on my Lenovo 330S 15IKB and is working fine, right now the system update shows the Catalina upgrade, is it safe to upgrade to Catalina from Mojave on my Hackintosh? At the moment I can't use the App Store, for some reason it doesn't connect. Thanks in advance.
I can't use the App Store/iCloud ... It looks like you resolved your issue. Can you suggest anything that I could try to get the App Store/iCloud working on Catalina? Thank you!
AlPaczino
CPU: I9 9900K
Post by AlPaczino »
@MaLd0n
Hello MaLd0n
I have components exactly like you.
I used Clower, there was a sleep problem.
Sometimes it freezes when switching off.
Now I use OpenCore.
It's better with sleep. Sometimes it freezes when switching off.
I don't use DSDT, think it will help?
Could you send me your DSDT and your config.plist?
Thank you very much.
Post by MaLd0n »
AlPaczino, --Run_Me
AlPaczino
CPU: I9 9900K
Post by AlPaczino »
I couldn't send Clover, it's too big.
Is needed?
For now I'm on Sata disk but I want to change to m2.
Do you have problems on your computer with Nvram?
Thank you in advance for your help:)
Tazorro
CPU: I3 2130
GPU: GT 8800
Post by Tazorro »
Hi MaLd0n, thanks for your advice. I managed to upgrade perfectly from Mojave to Catalina with SMBios 14.1. I had to fix the audio at the end of the update. I enclose photo.
Did I also want to ask you to activate airdrop?
Thanks again
jurisjoel
CPU: Intel Core i5 4200U@1.6GHZ
Motherboard: 00GCY
GPU: Intel HD Graphics 4400
Post by jurisjoel »
Hi there, i successfully install Mac Os 10.15.2 on my Dell Inspiron 15R 5537 Laptop, manage to get everything working except when i am playing video with VLC or Other video Players, the audio comes out but then no video, please how do i go about it, does this got to do with Intel Graphics? any suggestion and work around will be very much grateful. Thank you
Post by MaLd0n »
jurisjoel, u need use a hackintool and create a video patch for ur hardware
Return to “Catalina (10.15)”
