MacOs Catalina Hackintosh
bibinalappatt
CPU: i5
Motherboard: intel
GPU: nvidia
Post by bibinalappatt » 09 Oct 2019, 15:34
09 Oct 2019, 14:06
bibinalappatt, use hackintool, don't exist magic in hackintosh, u need fine tune
what things need to done in hackintool sorry new to this
Aloisio
CPU: i73820
Motherboard: Asus P9X79 Pro
GPU: Radeon Asus RX580 8gb
Post by Aloisio » 09 Oct 2019, 15:48
Ola Maldon, este modelo de usb 3.0 tem support pela configuração Clover? ou só via kext porque tentei e não consegui via kext generic.
Controlador ASMedia® USB 3.0:
Post by MaLd0n » 09 Oct 2019, 16:02
Aloisio, depende do modelo, se for o hardware da sua sig, só com kext mesmo e a kext causa bastante problema
vc pode usar a mXHCD.kext, se não funcionar injete o seu dev id na kext ou fake via dsdt
Wizzard
CPU: Intel m3-7Y30
Motherboard: Teclast F6 Pro
GPU: Intel HD 615
Post by Wizzard » 09 Oct 2019, 19:51
What can be wrong when I get kernel panic after booting to freshly installed system from SSD after initial install from USB?
No matter if I choose config or config2, the system always restarts before it loads the graphical installer.
Before I used Mojave with no problem.
Aloisio
CPU: i73820
Post by Aloisio » 09 Oct 2019, 20:16
09 Oct 2019, 16:02
Ok. consegui achar este Support NEC Renesas Chipset USB 3.0 Host Controller for old motherboard in Mac OS X, vou fazer o teste. :work:
Lulchev
Donator
Donator
CPU: i7-8086K
Motherboard: GigaByte Z370 AORUS GAMING 7
GPU: ASUS ROG STRIX GTX1080TI 11G
Post by Lulchev » 10 Oct 2019, 08:39
Hello friends! I need help :help to get the full potential of my Video/Photo editer machine again! I have created for High Sierra a DSDT patch from MaLd0n. Can I use them? I want to install fresh MacOS. Thank you people!
Here my config:
1. MB - GB Z370 AORUS GAMING 7
2. CPU - Intel® Core™ i7-8086K
3. SSD - M2 Samsung 970 PRO 1TB
4. Cooler - FD CELSIUS S36 WATER
5. Video - ASUS ROG STRIX GTX1080TI 11GB (but I will change it with Vega 64, and I need to know Can I put second Vega. Will it be helpful and can they work as one?)
6. RAM - 4x16G DDR4 3000 XPG D41 RGB ADATА
7. WiFi and Bluetooth - BCM943602CS (Can you recommend another Wifi because with that card I notice a big lag in the mouse and keyboard) :(
Post by MaLd0n » 10 Oct 2019, 13:38
Lulchev, system is installed? send me efi folder, i'll check
septicshock
CPU: i7-6700K
Motherboard: GA Z170m-D3H
GPU: AMD Radeon 570
Post by septicshock » 10 Oct 2019, 17:01
I'm having setting up OpenCore 0.5.1 config. Maldon, you had kindly created a DSDT for me and I can't seem to get it to work with or without the DSDT. Any help appreciated.
GA z170m-d3h, f21 firmware
Intel 6700K
Radeon RX570
Zarach
Geek
Geek
CPU: QuadCore Intel Core i7 8559U
Motherboard: Lenovo Ideapad 330 15|KB
GPU: Intel UHD Graphics 620
Post by Zarach » 10 Oct 2019, 19:04
Já saiu a versão final do Catalina da Olarila sem ser as betas?
HahAhAH
Post by MaLd0n » 11 Oct 2019, 04:25
Zarach, Sim
douglasfunkler
CPU: 7700k
Motherboard: z170 extreme 4
GPU: hd graphics 630
Post by douglasfunkler » 11 Oct 2019, 09:00
Any news on AMD RX 5700xt working under Catalina?
mariusrg
CPU: Haswell
Motherboard: Asus Maximus Formula VI
GPU: Nvidia 760
Post by mariusrg » 11 Oct 2019, 10:40
Hi, I need some help if possible.
I was able to install Catalina with no issue using the image provided here, but I'm unable to use my dsdt. Once I replace the one from the image, I cannot log, getting some weird errors messages. Also, noticed that some applications are suddenly crashing, like Spotify (cannot even open it), Chrome, not sure if it's something related with the image or the clover config.
I will attach also the send me output files, but if there are some other things I need to change in clover, please let me know.
Also, the boot process takes about double than the working clover/Sierra hack. (on a different partition)
Almost forgot to add, is there a way to make HWmonitor application to work, in order to be able to configure the fan speeds? (or if there are other alternatives)
Thank you so much.
Post by MaLd0n » 11 Oct 2019, 13:04
mariusrg, use ur dsdt without ssdt olarila
douglasfunkler, i think in next releases
mariusrg
CPU: Haswell
GPU: Nvidia 760
Post by mariusrg » 11 Oct 2019, 13:15
Hi, I tried that of course, replacing the DSDT files, but with my file I cannot boot at all. (while on the working build/partition works perfectly)
Post by MaLd0n » 11 Oct 2019, 13:17
mariusrg, post one photo
mariusrg
CPU: Haswell
GPU: Nvidia 760
Post by mariusrg » 11 Oct 2019, 13:33
Added, no idea how to add a jpeg photo.
Post by MaLd0n » 11 Oct 2019, 14:48
mariusrg, try it
SSDT-EC-USBX.aml.zip
mariusrg
CPU: Haswell
GPU: Nvidia 760
Post by mariusrg » 11 Oct 2019, 15:43
So use only this file, or together with my dsdt one?
Post by MaLd0n » 11 Oct 2019, 16:13
mariusrg, try together
mariusrg
CPU: Haswell
GPU: Nvidia 760
Post by mariusrg » 11 Oct 2019, 17:17
Thank you, I was able to boot now with both files.
Still, I'm not sure what to do to fix the sensors problem, with the HWmonitor app, in order to adjust the fan rpms. If I add fakesmc in clover I cannot boot, it gets stuck.
Return to “Catalina (10.15)”
