MacOs Catalina Hackintosh
silviolino
Geek
Geek
CPU: I7-7700
Motherboard: Asus ROG STRIX B250F Gaming
GPU: RX570 Red Devil 4GB
Post by silviolino » 16 Jul 2019, 22:55
Valeu!
MOBO: Asus ROG STRIX B250F Gaming
CPU: Intel Core I7 7700 3.60 GHz Turbo 4.20 GHz Quad-Core 8 Theads
WaterCooler Corsair H45
MEMORY: Corsair Vengeance 16GB 2x8 2400MHZ
VIDEO: Radeon RX570 RedDevil 4GB GDDR5
FONTE: EVGA Supernova 850W B2
SSD m.2: WD 480GB
Anuloges
CPU: I9-9900k
Motherboard: Asus Maimus xi Code
GPU: AMD RX 580
Post by Anuloges » 20 Jul 2019, 13:22
Hi, i am having kernel panic after updated to the Catalina. also my slep is broken after update. can you please look in to it. thank you so much
Post by MaLd0n » 20 Jul 2019, 15:26
Anuloges, same files, check ur procedure
-Donated? Send me one PM-
Post by MaLd0n » 31 Jul 2019, 19:07
beta 5
karalis1
CPU: I5 4440
Motherboard: Asus H87-Plus
GPU: GTX 760Ti
Post by karalis1 » 01 Aug 2019, 10:07
can we update directly from B4 without issues?
Post by MaLd0n » 01 Aug 2019, 12:53
karalis1, yes
karalis1
CPU: I5 4440
GPU: GTX 760Ti
Post by karalis1 » 01 Aug 2019, 17:22
Thanks for the answer, do you also think we will be able to update to the stable release without having to re install it in october?
Post by MaLd0n » 01 Aug 2019, 18:59
karalis1, yes, same from b1 to last
GabrielIg
CPU: HP 15-bs212
Motherboard: Intel Core i7 7000u
GPU: Intel HD 620
Post by GabrielIg » 01 Aug 2019, 23:25
Hi. I have a problem with Catalina Beta 4 Publica. It does not start the installation. But the other betas had no problem. What can be?
ACPI says error
Post by MaLd0n » 02 Aug 2019, 02:53
GabrielIg, post one photo
GabrielIg
CPU: HP 15-bs212
GPU: Intel HD 620
Post by GabrielIg » 02 Aug 2019, 11:20
Hi This is the photo. I had no problems with Beta 1,2 and 3. But updating to Beta 4 is as the photo says. Maybe it's that Lilu and watergreen have to be updated again?
Clover 5033 incompatible mark, and when installing anyway, mark installation error.
Help
No me deja poner foto
Morselina
Geek
Geek
CPU: Intel Core i7
Motherboard: Intel HM175
GPU: NVIDIA® GeForce® GTX 1050Ti
Post by Morselina » 02 Aug 2019, 11:42
MaLd0n, currently on olarila there is beta 4 file, but beta 5 is out, can you post Olarila Catalina Beta 5 image?
Thanks in advance!
Post by MaLd0n » 02 Aug 2019, 14:16
Morselina, [Local Link Removed for Guests]
i'll update new links today for other server too
karalis1
CPU: I5 4440
GPU: GTX 760Ti
Post by karalis1 » 02 Aug 2019, 17:41
Done everything and it works fine as usual! Hands down the best forum on hackintosh! The only problems I encountered is about clover 5033 which seems to be installed but when I try to boot through my macOS partition it gives a black screen (everything works fine if I boot through my usb), and on the keyboard it seems that the caps lock button is disabled or not working properly (was working fine with Mojave), may be also because this is a beta since sometimes I noticed random bugs with other keys as well. Anyone encountered one of these problems in beta 5?
Post by MaLd0n » 02 Aug 2019, 18:25
karalis1, check
EFI.zip
don't need install clover, just replace files in BOOT folder and Clover folder
cumpadi
CPU: Xeon E5 2680 V2
Motherboard: X79-2011 HUANAN
GPU: GTX 760 2GB
Post by cumpadi » 03 Aug 2019, 00:39
Instalei o Catalina mas deu esse KP. < In memory panic stackshot>. Pode dar uma olhada no arquivo que upei? :help O Mojave sobe normal. THKS.
CLOVER.zip
10.14.6 SSD250 GB X79-2011 HUANAN - XEON E5-2680 V2 2,80 GHz 10 Core - 32 GB DDR3 1866 MHz - GTX 760 2GB.
Post by MaLd0n » 03 Aug 2019, 03:31
cumpadi, posta uma foto do kp
osxone
CPU: haswell 4790k
Motherboard: asrockz97 extreme6
GPU: on board hd4600
Post by osxone » 04 Aug 2019, 21:57
Send me osxones-iMac.zip
10.15 Beta (19A526h)
Asrock Extreme 6 z97
intel hd 4600
16 gig memory
Catalina reports usb Acessory needs power
Post by MaLd0n » 05 Aug 2019, 00:19
osxone,
cumpadi
GPU: GTX 760 2GB
Post by cumpadi » 05 Aug 2019, 22:37
03 Aug 2019, 03:31
Desculpe-me pela demora e obrigado pela atenção. Não consegui fazer o up da foto. Mas fiz a cópia do mojave em outro ssd e instalei o pkg do beta. Depois fiz a atualização para o catalina beta normalmente. Vlw!
Return to “Catalina (10.15)”
