OpenCore Bootloader
erroruser
CPU: i9 9900k
Motherboard: asus z390-a
GPU: rx 590
OpenCore Bootloader
Post by erroruser » 28 Apr 2019, 19:43
cyberdevs, try this edit in the config an remove dsdt
Asus z390-A, i9 9900k, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, sapphire rx 590, fractal celcius s36
:superman :superman
free1975yuly
CPU: i7 hq6700
Motherboard: Asus ROG 752
GPU: intel hd 530 and nvidia 960
OpenCore Bootloader
Post by free1975yuly » 28 Apr 2019, 20:28
I couldn't install: SandyBridge won't boot, Skylake does not recognize screen resolution at all, and won't inject any kexts. Let's wait until official release.
cyberdevs
Developer
Developer
CPU: Intel Core i7 6700K
Motherboard: Gigabyte Z170X-Gaming 5
GPU: AMD RX 580
OpenCore Bootloader
Post by cyberdevs » 29 Apr 2019, 04:41
28 Apr 2019, 19:43
I tried them already and it still won't boot. When I select the USB all I get is a black screen :(
If you find my posts or apps useful please feel free to [External Link Removed for Guests]
erroruser
CPU: i9 9900k
GPU: rx 590
OpenCore Bootloader
Post by erroruser » 29 Apr 2019, 15:08
cyberdevs, try an change in the bios for Set OS Type to windows an make sure secure Boot Mode is disabled with boot args
-v dart=0 debug=0x100 npci=0x2000
:superman :superman
cyberdevs
Developer
Developer
GPU: AMD RX 580
OpenCore Bootloader
Post by cyberdevs » 29 Apr 2019, 19:31
29 Apr 2019, 15:08
Thanks for your help but the issue is the same, no mater what I do I can't boot the system with OpenCore, the system freezes right after I select the USB disk.
erroruser
CPU: i9 9900k
GPU: rx 590
OpenCore Bootloader
Post by erroruser » 29 Apr 2019, 19:43
im having an with OpenCore also with nvme m.2 as they are not showing in the boot selection only ssd
:superman :superman
cyberdevs
Developer
Developer
GPU: AMD RX 580
OpenCore Bootloader
Post by cyberdevs » 30 Apr 2019, 13:21
From what I know OpenCore is in its early days of developments and there must be some issues with drivers and hardware recognition.
I even tested the OC on my old SandyBridge and it won't boot either lol
So for now the only system that I successfully booted from is my SkyLake rig.
Let's hope that in the next releases it brings support for more hardware :smoke:
OpenCore Bootloader
Post by MaLd0n » 30 Apr 2019, 13:30
in my hacks skylake+ work good, very stable
cyberdevs
Developer
Developer
GPU: AMD RX 580
OpenCore Bootloader
Post by cyberdevs » 30 Apr 2019, 13:42
30 Apr 2019, 13:30
Yeah I guess the OC is working best with newer hardware.
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
OpenCore Bootloader
Post by mathewgx » 30 Apr 2019, 13:44
@MaLd0n , here is my current efi folder.
Could you modify it for opencore? I woudd love to try it.
Thanks in advance.
OpenCore Bootloader
Post by MaLd0n » 30 Apr 2019, 14:08
mathewgx, check first post for one good preset ;)
erroruser
CPU: i9 9900k
GPU: rx 590
OpenCore Bootloader
Post by erroruser » 30 Apr 2019, 15:48
:crazy: :frantics :frantics :crazy:
still having issues with nvme m.2 evo not showing in the boot selection
:superman :superman
cyberdevs
Developer
Developer
GPU: AMD RX 580
OpenCore Bootloader
Post by cyberdevs » 30 Apr 2019, 17:25
30 Apr 2019, 15:48
I noticed that OpenCore Detects my Samsung EVO 960 nvme drive. But since it has my main macOS on it I didn't try to boot into it using OC.
erroruser
CPU: i9 9900k
GPU: rx 590
OpenCore Bootloader
Post by erroruser » 30 Apr 2019, 17:31
cyberdevs, ya for some reason not for me an Maldon has the same nvme as i can only see ssd cards no m.2 ugh :frantics
:superman :superman
onemanosx
OpenCore Bootloader
Post by onemanosx » 04 May 2019, 04:13
2nd UPDATE: Alas, booted SKL laptop with OpenCore successfully after much tinkering. However, still need to figure out how to load I2C kexts. I'll take a rest now :mrgreen:
1st Post: Urghh, still not able to boot on my SKL laptop!
MSI B360 Gaming Arctic
OpenCore Bootloader
Post by MaLd0n » 04 May 2019, 13:55
-Update EFI in first post
onemanosx
OpenCore Bootloader
Post by onemanosx » 04 May 2019, 14:02
MaLd0n, laptop boots good now. All kexts loaded but have not solved i2c device yet. And anyway, whats up with the screenshot? Its not detected as MBP :lol:
OpenCore Bootloader
Post by MaLd0n » 04 May 2019, 14:13
onemanosx, change smbios(PlatformInfo) and add kexts in kernel(kernel/Add)
onemanosx
OpenCore Bootloader
Post by onemanosx » 04 May 2019, 14:22
MaLd0n,
I think kexts loads good. But no I2C trackpad.
Mac:~ vn7-592g$ kextstat | grep -v com.apple
Index Refs Address            Size       Wired      Name (Version) UUID <Linked Against>
   35    6 0xffffff7f83d91000 0x80000    0x80000    as.vit9696.Lilu (1.3.5) FDDBA1E3-B2DE-37FB-8997-88D28E69E007 <7 5 4 3 2 1>
   36    1 0xffffff7f83e11000 0x28000    0x28000    as.vit9696.VirtualSMC (1.0.2) 8814D940-2C42-3C45-9F42-8338AC4799EB <35 11 7 5 4 3 2 1>
   38    0 0xffffff7f83e39000 0x17000    0x17000    ru.usrsse2.SMCBatteryManager (1) F51BDDBC-E11D-3D46-BB61-6855F0FC7CC0 <37 36 35 11 7 5 4 3 2 1>
   39    0 0xffffff7f83e50000 0x11b000   0x11b000   as.vit9696.AppleALC (1.3.7) 4194C750-6151-377C-9C7C-E38886E3AC64 <35 12 7 5 4 3 2 1>
   40    0 0xffffff7f83f73000 0x7f000    0x7f000    as.vit9696.WhateverGreen (1.2.8) 2EB6FF06-A462-30B9-8121-88D5C9C6468D <35 12 7 5 4 3 2 1>
   41    0 0xffffff7f83ff6000 0xb000     0xb000     org.vanilla.driver.CPUFriend (1.1.6) A32118DA-09BD-37C3-BBF7-4DF6832CFC54 <35 11 7 5 4 3 2 1>
   42    0 0xffffff7f84073000 0x11000    0x11000    as.lvs1974.AirportBrcmFixup (2.0.0) B78B9C18-88E8-35E3-B489-C448FF764EE6 <35 15 12 7 5 4 3 2 1>
   43    0 0xffffff7f84318000 0x10000    0x10000    com.alexandred.VoodooI2CServices (1) 8D02CFDB-E378-3061-8591-7E199076722D <4 3>
   44    0 0xffffff7f84355000 0xf000     0xf000     com.XPS.VerbStub (1.0.3) 41D18E8C-8EFF-34A1-BD9C-2D806283284F <12 4 3>
   60    0 0xffffff7f842f4000 0x19000    0x19000    org.coolstar.VoodooGPIO (1.1) 584C5F47-466F-3585-9AFB-605777C0A2FE <11 5 4 3>
   61    1 0xffffff7f84328000 0xe000     0xe000     org.rehabman.voodoo.driver.PS2Controller (1.8.34) FE68E3D5-29E0-346A-9036-090411302A58 <11 7 5 4 3 1>
   80    0 0xffffff7f84001000 0x72000    0x72000    com.insanelymac.RealtekRTL8111 (2.2.2) 24D129C7-C25C-3D7B-9E10-EA71D9BE6511 <15 12 5 4 3 1>
   83    0 0xffffff7f84348000 0xd000     0xd000     org.rehabman.driver.FakePCIID (1.3.15) B185B092-1FC9-308E-B093-32FD88E5822D <12 7 5 4 3 1>
   87    0 0xffffff7f8433b000 0xd000     0xd000     org.rehabman.voodoo.driver.PS2Keyboard (1.8.34) 454845C4-36AE-37F0-995E-961CAAF609FB <61 58 17 7 6 5 4 3 1>
   99    1 0xffffff7f84084000 0x25f000   0x25f000   com.no-one.BrcmFirmwareStore (2.2.10) FEAD3CAB-F1B9-329A-8291-EAC222EBC0F0 <5 4 3>
  100    0 0xffffff7f842e3000 0x11000    0x11000    com.no-one.BrcmPatchRAM2 (2.2.10) EA8FADAF-E7F3-3CDF-8440-49C15C0E25F8 <99 24 5 4 3 1>
onemanosx
OpenCore Bootloader
Post by onemanosx » 05 May 2019, 00:32
I2C trackpad is now working simply by moving VoodooGPIO and VoodooI2CServices above in config.plist so they load firstly, then add VoodooI2C and lastly VoodooI2CHID. :work:
Return to “New Releases and Updates”
