macOS Mojave 10.14.6 - Out!
Post by MaLd0n » 22 Jul 2019, 17:13
-Donated? Send me one PM-
gagaraz
CPU: i9-9900k
GPU: Sapphire-RX 580 8GB
Post by gagaraz » 22 Jul 2019, 19:06
:superman :superman :superman
adriamartin91
CPU: i7 8700
Motherboard: z390 Aorus Pro
GPU: RX 580 Nitro+
Post by adriamartin91 » 23 Jul 2019, 13:01
22 Jul 2019, 17:13
It's safe to upgrade?
Post by MaLd0n » 23 Jul 2019, 13:04
adriamartin91, if u have a good config, dsdt, real vanilla hack, just update
adriamartin91
CPU: i7 8700
GPU: RX 580 Nitro+
Post by adriamartin91 » 23 Jul 2019, 13:15
23 Jul 2019, 13:04
Thank you very much!
danicao
CPU: i3
Motherboard: 33
GPU: 333
Post by danicao » 23 Jul 2019, 14:13
Não acho o link do google drive.
Post by MaLd0n » 23 Jul 2019, 14:32
danicao, não tem, só no nosso server agora
ohlongjohnson
CPU: i5-6500T
Motherboard: Dell 3050 Micro
GPU: Intel HD 530
Post by ohlongjohnson » 24 Jul 2019, 09:04
I was able to update from 10.14.4 to .5 but when i try to update to .6 it seems to fail and does not apply the update during next boot. Does anyone else experience this?
onemanosx
Post by onemanosx » 24 Jul 2019, 12:05
24 Jul 2019, 09:04
Smooth on my skylake laptop. However, took a while for my Cofeelake desktop. I thought the counter is never gonna move. I just left it and went out of the room. When I came back, the update was done :mrgreen:
Intel i7-6700HQ, 8GB RAM (UEFI Clover Mojave)
MSI B360 Gaming Arctic
Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Mojave)
ohlongjohnson
CPU: i5-6500T
GPU: Intel HD 530
Post by ohlongjohnson » 24 Jul 2019, 20:02
I ended up installing the new olarila 10.14.6 image on another drive(nvme) and imported all my stuff, works good! For some reason either installers always forget to install all the files needed in the efi folder, i have to add them afterwards to make it bootable on nvme. Works well on sata though.
Post by MaLd0n » 24 Jul 2019, 20:20
ohlongjohnson, if u have a full efi, just put efi folder into efi partition, don't need install clover, etc
janjao
CPU: i3 6100
Motherboard: gigabyte H110M
GPU: GT 710
Post by janjao » 27 Jul 2019, 18:32
Hello Maldon, update went smooth but after update trackpad stop working. Its voodooi2c kext. do you know how to fix?
Solved: reboot with -f argument, then rebuild kextcache, everything working again :)
Post by MaLd0n » 27 Jul 2019, 22:40
janjao, after updates, run olarila repair permission
janjao
CPU: i3 6100
GPU: GT 710
Post by janjao » 28 Jul 2019, 14:00
When i try to run Olarila repair permission, it crashes.
Post by MaLd0n » 28 Jul 2019, 14:37
janjao, ?
janjao
CPU: i3 6100
GPU: GT 710
Post by janjao » 28 Jul 2019, 14:40
Parece que o aplicativo está sendo bloqueado pelo sistema Maldon, não consigo executá-lo.
Post by MaLd0n » 28 Jul 2019, 14:43
janjao, é uma linha de comando, apenas coloque a pasta no desktop e roda o repair.command de dentro da pasta
use o master disable primeiro
janjao
CPU: i3 6100
GPU: GT 710
Post by janjao » 28 Jul 2019, 14:47
Ah sim, estava pensando que era o app. Enfim, funcionou, muito obrigado.
Dharc
CPU: Core i7-6500U
Motherboard: notebook
GPU: Geforce 940M
Post by Dharc » 30 Jul 2019, 18:24
No meu Asus a nova imagem dá panic no boot do instalador, desistí. Aparentemente é o CLOVER, pq tentei a imagem do Hackintosh World e coloquei o CLOVER do Olarila e deu o mesmo panic.
Added in 9 minutes 10 seconds:
Inclusive aparentemente é o mesmo panic que dá quando booto a imagem do Catalina.
Post by MaLd0n » 30 Jul 2019, 18:49
Dharc, vc tem de usar um patch completo pro vídeo na instalação em alguns casos gpu mobile
Return to “New Releases and Updates”
