Show Hidden Files and Folders
cyberdevs
Developer
Developer
CPU: Intel Core i7 6700K
Motherboard: Gigabyte Z170X-Gaming 5
GPU: AMD RX 580
Post by cyberdevs » 09 Sep 2018, 19:41
Eversince macOS Sierra 10.12.6 Apple added a new shortcut to easily toggle the visibility of the hidden files and folders simply by pressing the following keys:
Command+Shift+.
but on older version of Mac OS X (El Capitan and older) we still need to either type the commands in terminal or use other apps to toggle the visibility of hidden files and folders.
Here is my v2.0 version of the App that I created few years back. I still use it on older versions of Mac OS X and I thought you might need it as well :)
Show Hidden Files 2.0.dmg
If you find my posts or apps useful please feel free to [External Link Removed for Guests]
Post by MaLd0n » 09 Sep 2018, 19:45
:guitar
Allan
CPU: i5-3210M
Motherboard: InsydeH20
GPU: IntelHD 4000
Post by Allan » 11 Sep 2018, 00:58
Thanks @cyberdevs :D
cyberdevs
Developer
Developer
GPU: AMD RX 580
Post by cyberdevs » 11 Sep 2018, 04:05
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]Thanks
You are most welcome my friend :)
Hrnr881
CPU: I3-4150
Motherboard: B85M-G
GPU: HD4400
Post by Hrnr881 » 12 Oct 2018, 15:43
Hello landlord, I would like to ask it for Mojave OS
cyberdevs
Developer
Developer
GPU: AMD RX 580
Post by cyberdevs » 14 Oct 2018, 05:40
12 Oct 2018, 15:43
Hi there, this app will work on Mojave as well, just download the attachment in the first post, right click in the DMG, select open from the menu, when the DMG is mounted right click on the file once more and the app will open.
CompHuh
CPU: ConanHuh
Motherboard: Hp
GPU: 85643499438
Post by CompHuh » 23 May 2019, 19:44
Hi.
Can you perhaps add a glyph for the Show/hide hidden and system files command for custom toolbars?
Thanks in advance.
Return to “Apps”
