Olarila app / Images and Folders
Post by MaLd0n »
sarah2007, with my clover folder above dont work?
erroruser
CPU: AMD Ryzen 7 3700X
GPU: Sapphire rx 5700 XT
Post by erroruser »
sarah2007, if you have intel interenal will not work as intel not supported if its not do this
update your kexts then go to /Library/Preferences/SystemConfiguration/ an delete NetworkInterfaces.plist empty trash reapir permissions reboot
:superman :superman
Post by MaLd0n »
sarah2007, yes, check PM
mr.vs_k
CPU: i7-8700K
Motherboard: Z370HD3P
GPU: ASUS RX 580 8GB
Post by mr.vs_k »
thank you for your performance MaLdOn u r the best for sport
fritz122
CPU: i3-6600K
Motherboard: MSI-M250
GPU: Intel HD 530
Post by fritz122 »
Have you a idea for a nForce MCP79 Chipset with nVidia 9100M Grafik ?
which SmBios.plist could you use? It is a laptop of Medion Akoya P8610. Thanks for tips.
and which macOS could you use? There is a T9100 Intel Duo2Core processor in it which can SSE 4.2.
and have 8 GB DDR3 RAM inside.
Richard1057
CPU: i5-7400 3.00ghz
Motherboard: Asus H110m c/br
GPU: Nvidia GTX 750
Post by Richard1057 »
Olá! Estou com uma dúvida sobre qual destes Chipsets funcionaria em minha ASUS H110M-C-BR.
Sou novo com hackintosh :)
Obrigado desde já
Parabéns! pelo blog, Olarila é uma fonte muito rica em conteúdos :)
Post by MaLd0n »
Richard1057, serie 100/10
Richard1057
GPU: Nvidia GTX 750
04 May 2019, 00:04
vlw Cara muito obrigado mesmo :)
Rudiman
CPU: Intel Core 2 Duo E8500 @ 3.16G
Motherboard: Intel Corporation DP45SG (CPU
GPU: NVIDIA GeForce 9600 GT (ASUSt
Post by Rudiman »
Hi
So far I haven't got any success to enable usb (nor the onboard lan Marvel Yukon 88E8057 and wifi Intel Centrino Advanced N6200 AGN) on my
Sony Vaio
product VPCF12M1E
Name Intel Core i5 520M
Codename Arrandale
Specification Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz
see full details in attachment
thanks for Your advice.
regards
Rudiman
erroruser
Post by erroruser »
Rudiman, intel wifi will never work either get a usb or youll have to replace the chip for a compatible one for usb you should have them working after following the post install
:superman :superman
Rudiman
Post by Rudiman »
erroruser
Ty for the info; have a realtek 8188CU to use wifi; can Y tell me what I need to get that working. Also, can Y indicate which post install I should follow; seems to me I got something mixed up as I'm still not able to enable usb's. Btw I'm running Mojave which I cloned to a SSD from a VM.
Thank Y
Rudiman
maxservice
CPU: i5
Motherboard: apple
GPU: Nvidia
Post by maxservice »
how to find notebook series
Post by MaLd0n »
maxservice, what ur processor?
maxservice
CPU: i5
Motherboard: apple
GPU: Nvidia
i7
Post by MaLd0n »
maxservice, :whistle
what i7?
maxservice
CPU: i5
Motherboard: apple
GPU: Nvidia
intel core i7
onemanosx
Post by onemanosx »
:lol: :lol:
MSI B360 Gaming Arctic
Post by MaLd0n »
onemanosx, :mrgreen: :laugh:
natanzinho25
CPU: i7
Motherboard: asd
GPU: gtx1050ti
Post by natanzinho25 »
como eu sei qual é dessas opções devo usar para o chipset? o meu notbook é um lenovo ideapad320
Post by MaLd0n »
natanzinho25, skylake+ é serie 100/200/300
Return to “Apps”
